How is that I can get the station I want on one set and cannot make it work on another tv It appears that overnight you have made changes to how I listen to the music I like to listen to. The real question is when is my contract up. So I can shut this business down.
    Sergeant:
  • 378 Answers
I'm not sure what you're referring to.
I know Comcast is going all digital. You must have a digital converter (call 1-800-Comcast) soon. I believe 12 April to be their date.
As far as when is your contract up? That would be between you and the service provider in question... I'd suggest you contact them.
Shut this business down? Even as much as we love to hate certain businesses and their policies, they are generally much bigger than you and I, so I sincerely doubt it. If your contract is up, and you wish to move on to another company/carrier, I'd simply move on with water under the bridge.
Good Luck,
Mark
Posted on Apr 03, 2011
How to charge a dead battery with a charging station?
Disconnect the cables then charge the battery
Feb 23, 2016 | 2005 Volvo S80 2.5
TV does not autotune to all stations and does not store stations
The set has a EPROM somewhere that stores that info--either a stand alone one or one incorporated into the microprocessor the set uses.
The tuner if bad likely will not cause it to "forget" stored channels.
A possible way AROUND this would be the use of a cable/sat box connected to rear inputs on the set---you would sit on that input and change channels via the box which can usually be programmed to skip up/down channels you do not want---straight around the issue.
May 29, 2012 | Televison & Video
Does tuning stations in a dvd/vhs change the tv settings?
no, it will not change your tv settings. because your only tuning the stations of your lgv271. so don't hesitate on tuning your lg v271.
if you have any questions, just ask me.
Jan 14, 2012 | LG V271 DVD Player/VCR
I am unable to figure out how to remove SAP from 2 of my stations when I run the VCR through the Zenith TV. This is a relatively new problem. All the other channels I record are okay. I downloaded...
LEAVE TV UNPLUGGED OVERNIGHT TO RESET ITSELF. IT SHOULD BE BACK TO NORMAL AFTER POWER DRAINS FROM POWER SUPPLY. THAN GO INTO YOUR MENU SETTINGS AND TURN SAP OFF
Apr 19, 2009 | Samsung Televison & Video
Set clock
press source and go to stby press and hold the menu button till menu appears using the change station button select clock press and hold the change station button in till clck adj appears then press the source button then to have clock appear go to cd or radio and then press and hold the change station button in for clock to display
Mar 29, 2009 | Kenwood KDC-135 CD Player
The picture size has changed
The problem has been resolved on it's own. I'm guessing that maybe my cable company had changed the display setting on some of the stations. The picture of stations that I noticed the problem on appear to be within the screen.
Feb 07, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
NEW 37" LG TV & PEOPLE LOOK FAT & SUV'S LOOK LIKE STATION WAGONS
Go to your TV settings and change the "Zoom" function (not sure if LG has same terminology as my Sony) - you can flip through different options until you get to the setup that does not "stretch" the picture to fit the screen - if certain shows are filmed in 4:3 format (or square), they will need to be displayed with two black bars on either side (letterbox) on a widescreen set so the image is not distorted or stretched.
Feb 01, 2009 | LG 37LP1D 37 in. LCD Television
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Having to manually change TV input when switching between HD and standard
Salutations ScottB15,
Looking over your owners manual, I hate to say that it appears there is not a automatic way to switch between Ant to component video. As your television does not appear to have a built-in digital tuner you would be connecting it through the component connections, and as the only analog tuner is running through the antenna connection you would have to use that.
On the bright side with the transition to digital broadcasting this should be something you will have to do less and less. And once 2/17/2009 comes around you won't have to do it at all.
Wish I had better news, but at least there is always a bright side.
Jon
Go Ahead. Use Us.
Jun 16, 2008 | Insignia NS-30HTV 30" TV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
