Question about Toshiba 57H81 57" Rear Projection Television
My TV is Blowing bulbs and the fan is running. What should I be looking for to fix the problem?
    Sergeant:
  • 378 Answers
There sounds to be a heat problem here. I suggest a cleaning of the system. When you have it apart, using a can of compressed air and/or a shop vac, clean the dust from the system.
When installing replacement bulbs, be certain to NOT touch the lamp with your bare fingers. Always use a clean cloth or tissue. The oils on your fingers can likely cause the lamp to heat up and burn out.
If this doesn't resolve it, then I would consider a repair tech. According to my research, this TV is ready to be retired.
You can get a very nice Flat Screen with High Definition for quite cheap these days. My opinion on the 3D tv's are that they're not quite ready for main stream yet. Get one with either 120 or 240 Hz, as they will provide the best action video. 60Hz will be quirky/jerky, but still better than the picture on your old one.
Good luck,
Mark
Posted on Apr 03, 2011
My 60 inch Mitz keeps blowing bulbs
I have to assume you are referring to a projection TV when you say bulbs. With that in mind, the lamps do run hot so you want to make sure the TV has adequate ventilation around the TV grilles first. Next you want to make sure the lamp fan(s) are clean and no dust blocks the fan or cabinet openings the fan draws air from. That takes care of air circulation. The lamp itself has a relatively short life span of 2 to 3 years, I can't remember the hour rating off-hand. I have seen some last a year or just under but that's usually for high viewing times like 12 hours a day more than likely. Beyond that, the lamp ballast (power supply) could be an issue but it's less likely.
If you are changing your own lamps, make sure you don't touch the lamp with your fingers as the oils can from you skin can shorten the life of it just like it does with any quartz bulb, like halogen bulbs.
Jan 23, 2016 | Televison & Video
Mitsubishi projection tv keeps blowing bulbs! Every 6-12. Months. What is causing this tv to blow bulb?
bulbs normally fail from, overheat, loose in fitting or over voltage
if it is a screw in bulb then the problem may be from a loose earth (ground ) connection in the holder ( arcs just like a welder and that cause over voltage and surges to the bulb)
if it is a ceramic holder there should be a brass strip that rubs on the thread of the bulb as you screw it in
remove the power cord from the wall socket and bend the strip out to increase the load on the thread
screw in the bulb and every so often make sure that the bulb is tight
always make sure that the cooling fan (if there is one ) for the bulb is running at full rpms before ,during and after the unit switches on/off
Sep 11, 2015 | Mitsubishi Televison & Video
My Panasonic PT-60LCX64 television keeps having a problem with temperature. Every few hours, the TV will turn off and the temp light will blink 4 times. It will turn back on if we give it a rest of 10
Sounds like a fan issue which is possiblt slowing down as it gets warm. I would try removing the rear cover and set a fan behind it blowing on the chassis and see if the set keeps running if so the fans would be suspect.
Oct 14, 2012 | Panasonic PT-60LCX64 Television
Aveo radiator fan FUSE
You never replace a fuse that blows with a higher amp one . That's a good way to set your car on fire ,melting wiring etc.... The fan isn't blowing harder ,drawing to much current . lower resistance in the circuit .
Why is all this happening.????? Because you have electrical problems . Do voltage drop testing on the problem circuits , testing with a DVOM - digital volt ohm meter .
Where did you fine this fuse for The radiator fan is blowing to hard and is killing the fuse.So went from a 10 to a 15. My service info states it take's a 30 amp fuse . An it has two cooling fan relay , an a droping resistor . Unless your mixed up on your fan's , Heater blower motor fan ? From reading your post , i'd say you don't know anything about automotive repair . Suggest you take your vehicle to the dealer . We know your vehicle better then anyone else .
Mar 20, 2017 | 2006 Chevrolet Aveo
Tv does not swich on. The red led light plinks 5 times.
5 flashes, bad lamp and/or lamp driver
4 flashes, bad or stuck fan
There is a chance that the bulbs are not bad, but you will need a small fan to test this. Place a small fan blowing directly behind the set and run it for several minuts before turning the set on. This may help clear the code and allow you to watch tv if not then your lamp or driver has gone bad and needs replaced.
Jul 02, 2011 | Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
Four Blink Code on SONY KDS-60A2000 Rear Projection TV
I took a can of compressed air and blew air into the larger openings. A nice cloud of dust and several puffs of air later, the tv turned on.
Sep 20, 2008 | Sony KDS55A2000 55" HDTV
Loewe Articos 55 RP
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
Apr 24, 2008 | Loewe Articos 55 55" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
