Question about Honeywell Heating & Cooling
I am changing an old circular Honeywell AC thermostat to a new Honeywell VisionPro TH8321U thermostat. There are two wires coming from the old thermostat and I want to know which terminals do I attach the wires to on the new thermostat?
  • 182 Answers
Ac only?r and y
Posted on Aug 05, 2008
SOURCE:
Visionpro problems
Remove the batteries and remove the R or RED wire from the thermostat's sub base R/ RED terminal for 1 hour, if this does not work, replace it.
1-800-honeywell
www.honeywell.com
Dec 14, 2013 | Honeywell Programmable Thermostat Heater
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
Our visionpro 8000 thermostat has adjusted its day. It is currently one day ahead. We have misplaced our manual and we cannot seem to get the day to change. Suggestions?
This site has owners manuals for different types of thermostats. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/VisionPRO+8000.htm
This site is the manual for the "VisionPro 8000". You can look up what you need, copy or download. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf Roger
Apr 07, 2011 | Honeywell Heating & Cooling
My honeywell thermostat (TH8321U) touchscreen's icons only work on the left side which enables me to turn might heat on and off but will not allow me to change my settings?
Better replace the thermostat.
And for details, plz visit to:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating b>
Dec 07, 2010 | Heating & Cooling
Honeywell 8000 Thermostat relay switch clicking noise.
It's an expensive solution but doable. Look for Honeywell's VisionPro IAQ thermostat. It works much differently than a conventional thermostat and shouldn't click at all make sure it's the 3-wire version.
Aug 21, 2009 | Honeywell Programmable Thermostat Heater
Household Thermostat Replacement
you have to configure the thermostat to run the fan when there is a call for heat. look at the installation instructions and they shoud ask you if it is gas or electric heat if its electric then you are gong to have to configure it to makr e the fan come on with the heat. Good luck
Jan 25, 2009 | Honeywell Electronic Programmable...
Honeywell VisionPro 8000 cycles between Hot and Cold all day.
yes it sound like either they wired it wrong or when theywent and configured the settings this obe did not take to the configuration correctly. Have the contractor come back and do the job correctly or replace the thermostat. Thinks for using Fixya
Dec 24, 2008 | Heating & Cooling
Honeywell therostat wiring help
Don't assume the wires at the thermistate are correct.
I had similar and had to go all the way back to the heat/AC controller board. I found the colors weren't attached per spec so was fighting the origional installation at the new thermistat.
Also some digital won't control mutizones proerly
Dec 15, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
208 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
