Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
The freezer items are frozen,the refrig items are getting warm.i set it to the highest no.7 in the frig and its not getting colder
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
The ge refrig. is 9 years old. Regardless of the refrig. setting, from 5 down to one it is too cold. set on 3, after 24 hours it is 28 degrees in the crisper and 32 degrees in the main refrig. tried...
ok u ok u turning wrong knob..turn other knob the one with the letters. make the freezer colder than u make ref. warmer. that knob controls a flap that controls how much cold air flows from the freezer to ref. ok
Feb 12, 2011 | GE Refrigerators
Items freezing in the refrigerator
Due to the ice on the vent ( damper ) , the damper is probably frozen open , so it will not close , causing the refrig section to keep on getting colder . Put your hand over the vent and feel the air being circulated . Use a hair dryer on the vent for a time and ocassionally feel the vent to see if the vent closes stopping the air flow .
Aug 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Aug 23, 2008 | Jenn-Air JCB2388G Side by Side...
18 cu inch refrigerator ge hotpoint
my freezer is set higest and meats frozen ice cream soft the refrigator part is set on #9 but everything is not warm but just a little cool
Jun 16, 2008 | GE GTH18JBR Top Freezer Refrigerator
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
107 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
