Question about Electric Lawn Mower
Hi i have left my electric lawn mower out all year in all weather (i know) is it dangerous to plug it in and see if it still works
    Novelist:
  • 111 Answers
Make sure the unit is dry. If you have a blower I would blow it dry to make sure there is no water on any of the electronics. After that it shouldn't hurt to plug it in.
Posted on Apr 03, 2011
Lost power at spark plug!
Hi Kenny, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well.............. CHEERS..
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
May 03, 2016 | John Deere Garden
Engine will not start by the key and the electric PTO will not stay on
Hi John, I don't know if your mower is push OR ride on so The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope these help......... CHEERS..
How to test a lawn mower Key switch....
How to test lawn mower key switch
Apr 28, 2016 | Electric Garden
Older (probably 20 years) Rover mower 4 stroke (not self propelled) - no spark at spark plug (no it's not the plug) - appears to be an electrical issue - how can I source electrical components ?
Hi if U have a mower repair shop near U I would get the coil tested any good mower shop should have a tester also get the condenser checked & buy a new set of points U have to remove the flywheel to get to the parts .....good luck
Apr 20, 2016 | Garden
Corded electric mower loses power then comes back on during use
Same likely answer from several possibilities. Likely to be a poor electrical contact. Check *the supply had good contact for plug and an adequate fuse. *possible loose contact in the handle switch *if several years old, possible worn carbon brushes in motor. Easy to replace. *You should be using an RCD cut out switch. Check if mower works without it. Replace if dodgy
NB Only try to fix last two if you know what you are doing!
Aug 21, 2013 | Electric Lawn Mower
Club cadet riding lawn mower manuals
There is an oil reservoir on top of the diff. 10/40 engine oil or 10/50 if it seems like it is slipping in hot weather.
If there there are no oil leaks, then it should still be full.
It has no effect on the engine.
I would check the ignition switch for dirty contacts if it stops once the key is returned to On from the Start position.
Try disconnecting the electrical connections on the seat and transmission to see if that's the problem.
I always disconnect them anyway. I hate it when I need to get off the machine to move an object and have to restart each time.
Mar 26, 2017 | Garden
I left my electric drill in the rain! What can I do
get it inside and make sure it is completely dry before trying to use it...
then hope it works... not much else you can do...
heatman101
Sep 18, 2010 | Electric Lawn Mower
Batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
May 19, 2009 | Remington PowerMower 17-Inch 60-Volt...
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Electric Lawn Mower Logo
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
