Question about Kenmore Vacuums
Change hose - not able to get it apart - Kenmore Vacuums
My dyson animal sounds like something is stuck and flapping in the hose,filter, etc. I have taken it apart and I can not find anything. Have you had anyone else experience this issue?
try changing the filter. could be it is coming apart and making the noise. Also sometime these hoses will tear on the inside (lining of hose) and make a flapping or knocking sound. Check the hose as well.
Dec 06, 2016 | Dyson Dc50 Animal Bagless Upright Vacuum -...
I have no suction on my Eureka Smartvac. I cleaned the inside, it had been attached incorrectly so the inside compartment was full of lint, changed the bag but still no suction. My husband unhooked the...
Tear apart all hoses and make sure no clogging, also take apart to expose motor and make sure their is no dust on motor, this will cause symptoms you are describing, another thing check Impeller fan and make sure the fan is running and not blocked if fan is not working then will need to replace Impeller.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hi, my Dyson slim does not have any suction in the wand/hose. The vacuum itself works, just not the hose. I have unattached the hose, by unclipping it at the base, to make sure there are no rips or
Your changeover valve arm is more then likely broken or cracked. If so you will have to change out your under carriage assy. it's a pretty big job. I would recommend having an authorized Dyson service center change this for you as pretty much the whole machine will have to come apart. I attached a photo to show you the problem area.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 15, 2013 | Dyson Slim DC18 All Floors HEPA Bagless...
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
When I try to disconnect the hose in order to use the hand held hose with an attachment, the dust from the bottom flies into the air. How does this opening get blocked off to ensure the dust enters...
It is a matter of Physics. It seems like you have it running when you change the hose. ?? That's a no-no.
Basically you will have o take it apart until you know how it works or wont work
Jan 29, 2011 | Bissell Vacuums
How do you open a hoover steamvac agility to change the lower hose assembly?
ok. you will need a screwdriver phillips and a pair of ****. this is going to take about an hour. first take off the tanks, nexted on one side of the machine you will see i believe its 8 to 10 screws. (you don't need to take apart the handle) once you take all of them out, there's a plastic plate that the tanks sit on. take this off. (4 screws) got that done, seperate the two pieces.(the handle will come out so you have more space, it will be a tight fix) the haves are apart and you will see the hoses there. take out the big long hose(2 screws hold it on at the top) and at the bottom of this is the short hose that you need to replace. using your **** cut the plastic on either side of the notches on both sides. put the new hose on. then reverse your steps for putting back together. hope this helps out
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover agility steamer lower hose broken
take the handle screws all out and take the black peice where the hose attatches to loose. then pry handles apart gently and the hose peice will be able to be reached. not easy but can be done.
Feb 21, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
No Suction
Your Power head is blocked with hair or dirt,,or the hose which connects the Upright with the power head is blocked.
Try taking a steel coat hanger apart (straighten it out) and then push it into the pickup hose to remove blockage.
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
149 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
