Question about Dell Latitude D610 Notebook
How do you replace the Dell logo at the back of your lid? I want to make my own physical image (probably glowing) and put it at the back of the screen but I'm not sure if it's possible to remove the native Dell logo from there. Thank you in advance!
    Sergeant:
  • 267 Answers
The Dell logo you see at the time booting is the logo of your motherboard manufacturer. It uses the image associated with the program that helps you in booting your computer. If you want to change it, you should have proper knowledge of computer programming and IT. All you need to do is to identify the proper programs associated with the Dell logo and then hack the corresponding .exe or .dll files and replace the image with your own one in correct image format.
Hope this helps,
Mrityunjay.
Posted on Apr 03, 2011
Can i use a Lexmark mx810 imaging unit in a Dell B5465 printer? They appear to be the same part just different color.
They are probably physically the same but there are chips pn the units and the printer knows the difference so you will need to use the correct units or get reset chips that are programmed with the dell info
Jan 07, 2015 | Dell Office Equipment & Supplies
How do I back up my files on my Dell Inspiron 530?
Dell provide something they call "Dell PC Restore" or "Dell Factory Image Restore", which lives on a partition of your hard drive, and puts the operating system and drive back to their pristine state.
On my machine, I press Ctrl-F11 while the Dell logo is visible at start-up, and it gets me into the restore menu.Oh I see. That sounds like an auto-reformat. Quite nifty.
I wonder how they protect that partition? Viruses can be sneaky.
Aug 18, 2011 | Dell Inspiron 530 Desktop Computer...
Dell in inspiron 1545 wireless adaptor not turning on
Without knowing your exactyour Operating System, I cannot point you, directly, to your download. I can, however, bring you to the Inspiron 1545 Update Download page. Which is actually a better choice, as it contains all updates and upgrades and firmware for every device in your model:
First: be sure your physical On/Off switch is on. That will either be located on the left, front or right edge of your computer.
Dell also uses the Fn+F2 combination, on some models (without a physical switch).
If you have a Radio Tower Logo on your F2 key; hold down your function key and tap the F2 key (the same Radio image you see on your Fn Key - left of space bar). If it has a circle with a strike through it (Like a no smoking sign) that means your Wireless Radio is OFF.
To turn it ON simply hold down your Fn Key, again, and Tab the F2 key again until you only see the Radio Tower Image, without the Circle Strike Through Image; that means it is On...
**NOTE: Be Certain to minimize ALL windows to see the image when pressing Fn+F2:
1. Select <Operating System> from the drop-down menu on this page
2. Scroll to <Network>
3. Click the + Sign Left of network
4. Choose <Wireless Network Adapter>
5. Select Download Using Browser (if you only wish to do 1 upate).
Thank You For Choosing FixYa~!
Mar 22, 2011 | Computers & Internet
My Dell won't boot up at all. Tried booting up in safe mode and everything. Nothing seems to work.
Press F8 the moment you see Dell logo screen and select Last Known Good Configuration. If it still doesn't boot to windows, your operating system might be corrupted and needs reinstallation.
Dell systems has an Image Restore options. In Vista, press F8 on the Dell Logo Screen and select repair your computer. If you're running on XP, Press Ctrl+F11 to boot from the Factory Image Restore partition. Follow the instructions carefully to restore system back to factory image.
Jun 14, 2010 | Dell Inspiron 6000 Notebook
My dvd room (dell 1537)gets some physical error! I injected a cd disk; but it does not read... And i find no way to take the disk out.
Turn off computer
Locate a small hole in DVD drive lid.
Carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & remove the CD
Restart the computer and see if drive is damaged or not
May 10, 2010 | Dell Studio 1537 Laptop
I have 5 Dell 4310 WX projecors and I would like to display my logo when they start-up. Can this be done with the projector only or is a laptop necessary for this to happen?
I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
From the Setup Menu, or Others Menu, you can go into:
SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
settings menu consists of the following options:
CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
RESET—Select and press to delete the captured picture and set back to the default setting.
More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
Jan 14, 2010 | Compaq Presario M2000 Notebook
I want to bring my laptop back to factory settings
for a dell with windows xp
restart the system and right on the dell logo screen hold down ctrl and tap F11.. as in ctrl+F11
as you see the next page hit restore and it will start and complete in 10 min.
for windows vista_________________
restart and tap F8 a couple of times at dell logo
()choose repair my computer and then login as admin
() select dell factory image restore
careful it will wipe all the data that you you've put after getting the system
Dec 13, 2009 | Computers & Internet
Dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Feb 17, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron B130 DVD RW problems
First thing you need to check is whether the issue happens only if you are logged in to Windows or not. For you to check if it also happens outside of Windows, insert the Windows Operating System disk (XP or Vista) then shutdown the computer. Turn it back on. As soon as you see the Dell Logo, keep on pressing F12. Then select "CD/DVD ROM" from the choices and press enter. When you see the prompt "Press any key to boot from the CD", keep on tapping the "Enter" key. If your CD/DVD drive is working fine, you should see a page that'd say "Windows is loading files". If not then the system is not detecting your drive. Then check the BIOS page. F2 on the Dell Logo. Then look for Drive Configuration. If the drive isn't there, reseat it. Physically remove the drive from the computer and put it back in. Then restart.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Dell dvd not working
Please rate this if it helped.
Dec 21, 2008 | Dell Inspiron 1300 Notebook
Dell Latitude D610 Notebook Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
