I have a Siemens Washing Machine and when I try to wash my clothes there is a power cut in my apartment. The spining functionality works without any problem. I also notice that I can do the washing with cold water without any issues.
    Guru:
  • 500 Answers
You need to replace the element, it is defective. When you wash with cold water the element does not turn on, but as soon as you use hot water, the element would need to go on, then it comes into contact with water and "click" goes the power.
Hope this helps
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 04, 2011
Hi, I have a problem with machine siemens extraklasse f1000. Centrifugation is malfunctioning, the drum keeps spining slowly, and I can't extract the clothes...
Open the drum then disconnect the power in the first instance to remove your clothes. Then contact siemens for help.
Oct 28, 2017 | Siemens Washing Machines
I can't get the child lock to deactivate on my Seimens S12-38 washing machine. Anybody got a solution?
Deactivate child lock siemens washing machine S12-74 ...
www.fixya.com/.../t15773878-deactivate_child_lock_siemens_washing
Jan 10, 2013 - deactivate child lock siemens washing machine S12-74 - SiemensWashing ... -Press and hold the option down touch button for 5 seconds or until you seethe magic message 'Child lock released'. ... I can`t deactivate the childlock ... I CANTDEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES.
How to unlock washing machine door for siemens s12.38 ...
www.fixya.com/.../t11409270-unlock_washing_machine_door_siemens
Dec 21, 2015 | Washing Machines
Machne not spining fast enough to dry clothes, clothes still very wet after spin cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Washing Machines
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My siemens washing machine does not spin but the water in and out functions are normal
Hi, I have a Siemens WXL166AGB washing machine that has started jolting violently when on the spin cycle, as if something is out of balance, never getting fully up to speed. Subequently it cuts short the spin cycle and leaves the clothes wet. Any idea what it could be. Thank you, Phil Vanes
Nov 08, 2009 | Siemens WD61392GB Front Load Washer /...
THE MACHINE SHAKES WITHOUT CONTROL
During the spin cycle if your cloths are too heavy on one side you will get this problem, reposition the cloths and it should cure the problem, at least thats what I do when my machine gets to shaking.
Aug 28, 2009 | Maytag MAH8700A Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
