Question about KitchenAid Artisan
Hi there I managed to fog up the dials on my
Hi there I managed to fog up the dials on my tchenAid Artisan, is there anyway of getting them dry again or will it happen naturally over time. It was leaking, so I tipped it upside down to undo the screw and remove and clean the little round disc, no i think i have caused a new problem... Would tipping it upside down cause such problems. I had taken the water tank off. Thank you
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
I think they should clear by themselves, they are not sealed and can bee removed after only taking the very top (black Plastic) off the unit. You have to have fairly nimble hands but it can be done. The Dials come out with a quarter twist.
Posted on May 21, 2011
How do I dry only
When using the WD-1000 as a Dryer only, are you turning the rightmost knob Clockwise to the correct starting point?
Looking at the periphery of the knob, at the bottom, see the elongated "sausage" shape, outlined in blue? Turn the knob so it passes "Stop", and points there.
At the end of a completed Wash Cycle, that is where the pointer will be pointing. Once there, the machine switches automatically to Dryer Mode.
As long as the middle dial is set to a timer length greater than zero, the drying begins. I recommend turning the middle dial to somewhere around 2:00 o'clock, which corresponds to about 90 minutes if I remember correctly.
(You'll notice that is in the "Orange" area, meaning Full Heat - which is always fine because it never gets too hot anyway)
So, turn right dial to point to the "white sausage" at the bottom of the dial; Turn middle dial to 90 mins, or so; (Left dial only controls "Spin" speed - just set to max); and close the door. (It should begin drying)
Feb 14, 2015 | Malber WD1000 Front Load Washer/Dryer
Display Problem
Fix it before it goes bang. It will 85% be the steam boiler seals leaking, remove the lid and have a look when operating, keep your fingers out, use your eyes.
Jan 22, 2014 | KitchenAid Coffee Makers & Espresso...
Steam on off switch not working
You need to take the top off and also the upper red housing. The switches often fail because of internal leaks so if your dials have been fogging up during use then sort the leaks out as well.
Jan 14, 2014 | KitchenAid Artisan
Humidifier not getting enough water
I suggest you buying the FOG RING: http://www.neotizen.com/main/main.php
This is really helpful for HUMIDIFYING any area, it is very cheap and it produces a lot of cold vapor.
Dec 28, 2013 | Trion ComfortBreeze CB707 - Atomizing...
Cloudy screen
It's possible that you have moisture on the inside of your camera, causing the sensor to fog up. It is also possible that you have fog on your lens as well. I have had cloudy images with my Nikon when it fogged up inside. The best thing to do is to make sure it dries out. This usually solves itself so long as you are in a dry location, but if not I would take your camera to a local repair shop to have it looked at and fixed. It really does sound like a moisture issue however. Do NOT dry your camera using heat or anything! If it doesn't dry on it's own, take it to a pro to get it fixed.
Jul 09, 2013 | Nikon Cameras
Is there anyway to only dry the dishes? Sometimes the dishes don't get all the way dry and I just want to run the dry cycle again. Thanks! Dawn
You could simply open the door at the end of the cycle and let the air do the job. If your dishwasher is controlled by a manual dial, you could open the door, move the timer past the wash cycles stopping on the dry cycle and close the door to start another dry cycle. This option is expensive, by the way.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Epson Artisan 800 trying to make a fax and it says no dial tone.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte_2/misspell.gif) repeat-x scroll center bottom; } Hi,
Please check your phone line followed by the connectivity between your phone line and printer/Fax..
You can go through the user manual else cam download the manual from the link below :-
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=108745&prodoid=63082419&category=Products
If your Fax doesnt work, let me know!
Thanks !
Sep 16, 2009 | Epson Artisan 800 All-In-One InkJet...
I have a grey film on my flat metal beater anyway to remove?
Gray film may be a result of tarnishing. The metal beaters are made of a burnished aluminum material. The burnished aluminum may not be washed in a dishwasher, cannot be left to soak in a sink, and must be towel dried immediately after washing as opposed to being air dried. If this has been done incorrectly, this may lead to tarnishing of the beater, which can be described as a "grey film."
Jun 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan Logo
137 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
