Question about Acer (54.AA806.001) Sound Card
I have the Acer Aspire One. My sound works however, every time I try to use Skype a blue screen comes up and it restarts the computer. As well when I play music it always skips and there is a static noise in the background. I have no idea how to fix it.Can you help Please and thank u!!!
  • Acer Master
  • 27,725 Answers
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
another one of the possibile reaons is
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Posted on Apr 03, 2011
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Acer aspire 4935G lap automatically getting restart and apears blue screen
Hello download or renew the missing drivers here at acer:
http://support.acer.com/product/default.aspx?modelId=35
Please select your windows system.
Unzip the file before you install the driver.
Reboot after the install is done.
Try to renew the screen card driver.
Blue screen of death is always a faulty driver.
Good luck
Nov 07, 2012 | Acer Aspire 4710 4920 4935 4930G 4930...
Cannot on my computer
hi
you may have bad software drivers. what software did you recently install , if any ?
acer has techsupport to address this issue : call 1 855 661 6161
go to this Acer site , http://supportforacer.iyogi.com/aspire/blue-screen.html
Feb 26, 2012 | Acer Aspire 4315-2963 Notebook
I tried to skype today but i couldn't got a message that skype can't access my sound card. the internal microphone to my acer aspire 5517 seems not to be working. how can i fix it
Reinstall the sound driver on your laptop. Go to google and search for "Acer driver" and look for your laptop onto the Acer support website. Click on sound and download the right driver for your laptop. Install it and restart your laptop.
Mar 03, 2011 | Acer Computers & Internet
I have an acer aspire 5534 and I uninstalled mcafee it instructed me to restart and I do but then when my computer powers back on I get a blue screen with an error msg saying windows shut down...
u could try and use F8 when turnning it on by holding it down till writing comes up then look for lastknow configuration use the arrow key to highlight it then press enter
Nov 07, 2010 | Acer Aspire 55345410 Notebook
The ACER Aspire 5610Z is stuck, upon rebooting, on the large ACER Intel window. I push the start button for a length of time, and it won't restart. What else can I do? The problem arose upon a reboot after...
Try booting into safe mode. When the computer is just starting, tap the F8 key and keep tapping it until the safe mode options come up. Select "Last Known Good Configuration" and let it continue booting from there. Once inside Windows, check Windows Update to see if your computer had tried to install update KB977165. This recent update has been known to cause problems in XP, including the dreaded BSOD (Blue Screen of Death), due to malware infections. You may want to try the ESET online scanner on your machine and possibly Malwarebyte's Antimalware, available at www.download.com. Always keep running the scans until your computer comes up clean.
http://blogs.zdnet.com/hardware/?p=7377&tag=nl.e539
Feb 22, 2010 | Acer Aspire 5610-4648 Notebook
if your computer is getting this blue screen of death,then try getting in safe mode with networking of the computer& if you are able to go there you can uninstall & reinstall the video driver from that safe mode page because you will be able to work on that page...
Apr 25, 2009 | Acer Aspire One N270 Notebook
Unable to recover system
see if your system restore is in my computer c:\ drive
should be there it will probably say acer on the folder
restart while in restart press F7 then when options appear select boot with cd or cd/dvd
then enter this will start the system with the cd
if it does'nt start the win setup then restart might need to try a couple times
if setup still does'nt start then make sure the cd is the right recovery disk
Jan 27, 2009 | Acer Aspire 3680 Laptop
Acer aspire 4520 -5458 gets a blue screen error message....
your harddrive has gotn fucked up or some thing try install ing and formating it from a cd if that doesent work order a nwe harddrive
Jan 02, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
