Question about Fisher and Paykel WA37T26G Top Load Washer
WE have a F&P WA37T26G top load washer. A load was unbalanced, now the machine will not spin.
  • 3 more comments
  • pwp100 Apr 03, 2011
    3 lights rinse through spin. no flashing
    last 3 are on, all others off. The machine will fill, agitate, will not spin out
    thanks
  • pwp100 Apr 04, 2011
    will try those. thank you
  • pwp100 Apr 05, 2011
    The 2 solutions didn't work. THe lid switch is working, and there doesn't seem to be a belt . It looks like it is direct drive.
  • 4,323 Answers
Hi
The issue is with either the belt or the lid switch assembly. You can try to test the lid switch first with a voltmeter; if bad then it should be replaced. If the switch is fine then you will have to open the unit from back to replace the belt. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 04, 2011
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
What lights are flashing on the machine? I believe there are eight lights. Which ones are on, and which are off?
Posted on Apr 03, 2011
  • Richard Roth
    Richard Roth Apr 03, 2011
    OK, let me look in my database and I will post back to you.
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Why is the washer Full of water but won't power on?
It sounds like the pump has went bad & also taken out the main board.
Common fault is pump.
May 10, 2014 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't empty and spin
You either have a blocked water pump or more likely a blocked diverter valve. Easy to fix if you are handy. Tip machine back on a 45 degree angle and let rest against the wall. It is a matter of disconnecting a coupe of clamps and twisting the pump counter clockwise.
Dec 25, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Our fisher and pykel always off balance( wont spin at all because of it)disconnect unbalance sensor?
Try to raise your back feet on the washer, so that it tilts forword away from the unbalanced censer
but not to much,or it will bang on the front. Hope this helps
Oct 18, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Will not deain or spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Washer won't spin, keeps giving unbalanced alert
You probably have a faulty Out of Balance Switch.This is a little micro switch inside the control box underneath the main computer module,right hand side.You will need to remove the modle to get to it.
May 31, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and paykel washing machine becomes
i think that 1 or more suspension rods r faulty. lift the lid and at the front of the machine u will see 2 plastic covers, remove the covers and undo the screws underneath. now lift the front of the hob up gently and u will see the suspension rods. they r easliy replaced. but first see if they havent just popped out. if they have just popped out look at the other 3 and refit to how the others are.if u need more help or u find another problem reply back and i will help u more.good luck
Apr 20, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Becomes unbalanced easly and now wont spin
Sounds as though the Balance Weights have become dislodged? If this happens there are sensors that detect when it becomes out-of-balance, and shut it off to avoid any further damage.
Feb 04, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Fisher and Paykel WA37T26G Top Load Washer Logo
315 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
