Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
Hot battery,will not turn engine every time,keep bumping key and will start turning engine seems like trying to start with too much compresion
  • 718 Answers
If your unit has OHV engine you need to check the intake and exhaust valve gap. Call your local repair shop to get numbers and check this website out. Go to smalleng.com they have a video for just what you are looking for. Good Luck...
Posted on Apr 03, 2011
Will bump start but not off key
If the car turns over well..so you can crank the engine using the key and it turns over fast, but it won't start, could be down to low fuel pressure, possibly fuel pump. Could be the coil ( which I doubt as the car starts when bumped) or, like you say, the plugs. The fact that the engine fires up when pushed, and the lack of info regarding how well the engine turns over using the battery, seems to me that it could be either a bad earth ground from the battery, but more likely a bad battery that's lost it amps and losing its charge quickly when the engine is off. Engines can turn over with a bad battery but the amps are bad and it dies quick. One thing you could try would be to see if you can get someone to jump start the engine using cables. If the engine starts its most likely the battery. You may still encounter a problem using cables because there still might not be enough amps getting through, so the best option would be to try a different battery first. Your car is starting when bumped which makes me think the plugs are ok, as when power reaches the plugs, they heat up and create combustion. If the fuel pressure is low, this could cause your problem, as the bump will increase the pressure and supply allowing it to start. I'm not sure if your car is electronic pump or mechanical. If it's electrical this could be unlikely the cause unless the power drain when trying to crank the engine from the battery is causing poor fuel supply from the electric pump. There is another thing..do you allow enough time for the glow plugs to heat up? some cars as they age prefer some time with the key on to the point the dash lights are on, and wait 30 seconds and then turn over the engine, this power supply can allow the plugs to heat up prior to being turned over. One other thing could be the pre- heaters. I'm not sure the exact names, but modern engines have a system that pre-heats the plugs, like pre-coils or something. This could be bad.
Try this first:
turn key to the point the ignition is on fully with lights on but don't turn over the engine. Leave it 30 seconds and then turn over the engine. See if this works. This will help heat the plugs and prime the fuel pump.
If this does not work, then try to get someone to jump start your car using cables. Again follow the previous tip. If this works it's likely your battery.
If this does not work, try a different battery. hopefully someone can loan you one. If this works, it's your old battery. some batteries are maintenance free, so you shouldn't top up with distilled water, but some are not and lose water. If it's low, top it up with distilled water. Do not use tap water. Be careful handling the battery with the caps off. Do not over fill.
If this does not work, try new glow plugs.
If this does not work, it could be the fuel pump causing low pressure.
Lastly, when you key the engine to turn it ove, does it just click? If you just hear a click from the starter motor, then either the battery is bad, a bad earth ground requiring a clean of the terminals and reconnecting them, or new starter motor. If you just hear a click and the battery is good, see if you can get someone to whack the starter motor body with a hammer and it may start. Be very careful not to have the car is gear, to no get your hand caught in moving parts, etc. This is at your own risk, please google how to do this and then decide if you wish to try.
There can only be so many problems. Power or fuel. It starts when pushed, so it gets fuel from the pump when pushed. The plugs get power when pushed. The key is does it turn over from battery, and is it getting enough amps. Good luck
Nov 06, 2013 | Peugeot Cars & Trucks
My 2003 saturn lw200 will start but will not stay running. The lock light has came on but is now off. how do i reset the anti theft
If it is just a relearn and you have no issues with the security system the procedure to "teach" the vehicle the transponder code for the "chip" in your key is as follows. Turn the ignition and just turn the key enough so the engine turns for just a second. Not enough to try and start the vehicle jusy enough to "bump" the engine quickly. Once you bump the engine, release the key and leave the key in the "on" or "running" position. Your security light should be flashing if you're dealing with a security issue but that doesn't happen 100 percent of the time. Leave the key in the on position for 10 minutes. If the security light is on or flashing it should shut off after 10 minutes. After the 10 minutes turn the key off and without removing the key turn it to where you bump the engine like before and repeat the 10 minute wait time. You will need to do this 3 times totalling 30 minutes. The 3rd time turn the key back off and without removing the key try and start the vehicle. This is the only procedure that can be done without diagnostic equipment and providing you don't have an issue with a part in the security system or there isn't another problem, this should reprogram your vehicles security system. Hope this works for you and hope I was able to help....
Oct 11, 2013 | Vehicle Parts & Accessories
Weak starting
Evan, you may have two interconnected but otherwise unrelated problems. Problem one is your starter sounds like it is wearing out due to the second problem you have. If this has been going on for a while and you have had to repeatedly crank and crank the engine the starter gets hot and wears prematurely. The "Bendix" gear on the end of the starter isn't always extending into the ring gear on the flywheel and they scrape against each other when you try to start the engine. The bump you feel may be a damaged tooth (or teeth) in either the starter or the ring gear it turns or the bolts holding the starter may be getting loose (or both). The second issue feels like a defective ignition switch in the steering column from the information you have given so far.
May 13, 2013 | Nissan Maxima Cars & Trucks
1998 vw beetle wont start when turn key but bump start works but doesnt want to stay running\
This sounds like the anti theft system is active, you jump start it but it dies out after a few seconds , if this is correct then try another key. the other thing can be a weak battery make sure the battery is fully charged and good,
Oct 01, 2012 | 2000 Volkswagen Beetle
I have a 2006 Jeep Grand Cherokee Limited with a 5.7L Hemi. I have had a starting issue I turn the key - nothing Turn the key a few more times the engine cranks and starts. It was doing this last spring...
is the engine grounded to the body? if so, you may have a key issue that's only going to get worse. your key is coded, black square ignition key right? $75.00 dealer only. sorry but it sounds like that's your problem. almost like a valet key. only works for short time and if you keep using it, it will blow the fuel pump$379.00 please do more research! hope this helps,and merry christmas from me and mine,to you and yours.
Dec 26, 2010 | 2006 Jeep Grand Cherokee
Starting issue with John Deere 108 lawn tractor
If it seems as if the engine will crank maybe one or half turn then stop turning it maybe that the valve lash needs to be checked.When valve lash is more than .004 the compresion release will not be affective therefore the cylinders will have too much pressure built up to crank over.Set intake/exhaust valves at .004 when piston is 1/4 inch past top-dead-center on compression stroke.
May 21, 2010 | Garden
Car won't start
Try to keep bumping the key like you were trying to start it and hold it till it starts if you hear it start to turn. Its most likey the starter
May 03, 2010 | 2007 Toyota Camry
I have a 1998 f-150 4.2l v-6 tryed to start it today it turned over and did not catch. turned key to try again it bumped the starter but would not turn the engine over. I tryed jumping it but I knew I had...
When you say 'it bumped the starter but did not turn the engine over' and 'it bangs the starter' it sounds like you mean it hits the flywheel and will not turn the engine. If it engages and does not turn the motor you need to try to manually turn both directions. Do not have the key in the ignition. If it won't turn you may have a froze up motor.
If you mean the starter spins freely but won't engage the engine - than you need a new starter. Let us know what you find out.
Mar 06, 2010 | 1998 Ford F150 Regular Cab
Passive keyless entry light on in my 1994 Corvette
there is a fuss that should have been pulled be 4 removing the battery if you have your owner Manuel it should show where it is located most times right side kick panel or rite of glove box you can try locking&unlocking your door with the key then put the key in ignition turn key on till lites on dash come on 3times do this leaving key on3ed time Waite 20mi.then turn off and try starting keep battery charged
Sep 05, 2009 | 1994 Chevrolet Corvette
1995 Nissan Difficult to start in hot weather.
the reason it's starting after a few turns of the key is because when you're the ignition position, you're priming the engine to start. By priming it repeatedly, you're making it easier on the starter to catch when you finally try to turn the engine. I would first check the spark plugs and electrical wiring.
Aug 26, 2009 | 1997 Nissan Maxima
Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
130 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
