Question about Altec Lansing IM7 (WMM137039)
Speaker going out
One of my front speakers is checking in and out. Sounds like a short.....
  • 2 more comments
  • Not today Sep 23, 2008
    One of the speakers worked on and off for about 6 months, now it seems to be completely out, - Other speaker works as fine. I can't even get into the thing to see what's going on, it sounds like a flakey connection to me.
  • Anonymous Dec 04, 2008
    my left speaker crackles on higher volumes. my bass level also seems exaggerated even with bass level on remote down v low
  • jcho47 Feb 19, 2009
    Does anyone know how to properly disassemble the iM7? I was able to remove the battery doors, bottom panel, side speaker covers, side speakers, and rear grilles, but I am unable to go further. I still cannot loosen the top half of the rear handle panel, the front iPod bay, and subsequently the front speaker grilles. After removing the handle rubber lining the piece seems to be PVC-glued to the main body but I cannot be sure. I don't want to cut apart the unit just to find out that there was a screw or snap I could have removed beforehand. I was wondering if anybody had any experience with taking apart an iM7.
  • Anonymous Apr 03, 2009
    My IM7 is only 1 year old and everything is working intermittently - I am thinking that something is loose inside. I too tried to take the unit apart and only could get half way. If anyone has experience taking this thing apart could you please post some instructions.
    Thanks
I had the same problem. Eventually the other speaker quit also. The problem was a broken wire under the door. This required complete disassembly of the unit just to get at these two wires. Sorry the news isn't better.
Posted on Jan 04, 2009
Pioneer VSX-D307 has no sound from right front speaker.
Did you connect a known good speaker to the amplifier's right front output connections? Make sure you also have known good wires for the front right as well. Make sure balance control is set to the middle and not just to the left.
Aug 22, 2016 | Pioneer VSX-D307 Receiver
2007 cierra ,my radio cones on but not putting power to speakers except to 1 front speaker and it has almost no sound ,up full and very screechy . do I need a new radio ?
Sounds like a wire is shorting out, probably in behind the stereo, but more likely in the back where the speakers connect. Check for something shorting out or a wire grounding out near the speaker.
You can trace back from there.
Other than that probably is the stereo.
Dec 01, 2014 | 2007 GMC Sierra 1500
Speaker wires accidentally touched.
it sounds like the cone in the centre has blown. Use a 'spare speaker' not one from the system and try it, is should work, but if it was the centre speaker cable that shorted, should you get no sound from the spare it sounds like you have blown that part of the system which will require professional repair. Sorry
Jan 17, 2010 | Yamaha HTR-6030 Receiver
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
Put in new front speaker in car and they worked good for a couple of hours, now there is no sound from the front or back speakers. I unhooked the front speakers and put one back then rear speakers worked...
Hello. Sounds like the amplifier is damaged and or could be a short from a front speaker wire to the car chassie ground. Assuming that the four speakers are driven by the same deck. I would first varify that the amplifier in the deck (radio, CD, etc) is functioning properly if it is being used.
Jan 21, 2009 | Car Audio & Video
Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Jan 15, 2009 | Yamaha RX-V661 Receiver
Front right speaker sounds distorted
Check all wire connections, check all wires for frays make sure none of them are chaffing on any sharp metal, try different cable or wire between the tuner and or amp and the speaker sorry to say but it sounds like you possibly may have shorted out a Chanel. not saying you did but you may have. you may have to open the system smell the circuit board, to see if there was any (magic smoke), if so you can try to replace any of the bad components check and try to repair any opens, or try to find any loose solider connections or any burnt resistors or fluid leaking from capacitors if all is well and you don't find anything which you probably will if ya blew a Chanel, have it repaired, or buy a new one or go to EBay............
Oct 30, 2008 | Denon AVR-5805 Receiver
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
When i turn on the cd player the sound from the components vuts off but the sound coming through the subwoofer stays on??
The Sub gets it's output from the pre-amp circuit, whereas the components get their output from the main amp circuit in the unit.
Sounds like it could be a short in the speaker wiring or a blown speaker. Check all wiring to the speakers.
Check all speaker wires from the unit to the speakers.
First check that each pair of speaker terminals at the speaker end is not touching. Or, a wire fell of 1 terminal to rest on another.
Best way to check if it's a blown speaker or a wiring short, is to disconnect all speaker connections ( at the speaker end ) making sure the disconnected wires don't touch each other or any metal in the car. press the reset on the unit and power up. If the unit powers up ok, then its a blown speaker.
Otherwise it's a short in the wiring.
If it's a blown speaker, you can connect 1 speaker at a time and the blown 1 will send the unit into protect mode again.
If it's the wiring, disconnect the unit from the wiring and use and ohm meter to check each pair of cables. A reading suggests a short.
If you don't have an ohm meter a battery and bulb will do. This method usually works on a short.
If you have no joy with either method, take each speaker wire in turn and check with a source of earth (anything metal connected directly to the body of the car, cigar lighter main body when pulled slightly out is good)
Regards
Philip
Jul 20, 2008 | Car Audio & Video
No volume
Protect is on because one of your speaker's or wires is shorted out. It comes on to protect the amp from frying, check ALL of your wiring and speakers for shorts to ground, NONE of the speaker wires should go to chassis ground only the stereos negative (-) speaker termina.l
Checking your speaker is easy, take a (D) cell battery and a couple of wires and connect the wires to the speaker, you should hear a click if the speaker is working properly. Good Luck
Leadispenser
Jun 10, 2008 | Kenwood KDC-MP235 CD Player
Altec Lansing IM7 (WMM137039) Logo
953 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
