Question about Weber Q Grill
Q200 weber grill getting gas flow but only at low and cannot regulate flame or raise temp for cooking
    Brigadier General:
  • 4,736 Answers
This sounds like a case of the OPD tank valve on the propane tank has locked up your regulator. In which case, turn the tank OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Now, turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is completely open, light the burner farthest from the tank first and turn it to the highest setting. If the flame appears to now be normal, light the remaining burners following the same procedure. If all burners have returned to normal height, you solved the problem. Always remember to turn the tank valve ON VERY, VERY SLOWLY.
If the above doesn't solve the problem, you may need to replace the regulator/hose assembly, which you can purchase from any home center or hardware store that sell gas grills and accessories. Take your old one with your for comparison purposes.
Posted on Apr 03, 2011
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Weber Q Grill
I have weber q200 grill and only 2/3rds of the burner will light. what is causing this?
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 08, 2010 | Weber Q Grill
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Apr 27, 2010 | Weber Genesis Silver B Grill
Temperature will not reach past 180 degrees
you may need a grill clean or you need to adjust the air flow to your burners
Apr 20, 2010 | Weber Genesis Gold B Grill
Weber Q 220, low flame and temp
Try replacing the regulator
Dec 31, 2009 | Weber Q Grill
Just bough weber Q200 grill. Is it normal that the flame burns so low and blue?Used to large flames off conventional grills. Thanks.e.
I have used the Q-series for 2 years. The blue and low flame is absolutely normal. Weber's philiosophy is of avoiding flare ups when grilling for best taste. I love this grill - very easy to clean, uses less gas and makes great food.
Aug 23, 2009 | Weber Q Grill
Low gas flow - low heat
Hi Lyon,
Yeah, it's the regulator. Fortunately, they're cheap and easy to replace!
You can look on line for part number 80012. Or you can remove yours and take it to Home Depot or Lowe's in the outdoor cooking area and match up a replacement. <--- they're all the same... just make sure the compression fitting (the brass end) is the same size.
The only other thing I could recommend is this... Turn the LP bottle completely off. Then completely remove the big plastic knurled knob from the tank. Now replace the knob back onto the tank (all the way and make sure it's tight). Then S L O W L Y turn the gas back on. Now try your pit. If you get the same flame, it's the regulator. If you get full flame, you just reset the safety device inside the tank.
I'm betting regulator. Good luck and happy cookin'!
SG
Jun 03, 2009 | Weber Q Grill
The temp/flame on my weber grill won't get hotter
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Mar 06, 2009 | Weber Spirit? E-310 Propane Grill
The only way you can fix the low flame, low heat problem, is to remove the grill, take a medium sized paper-clip (staightened out) and clean out each individual hole on the steel burner, flame tube. (I'm sure there's a technical name for it).
Since they (the holes on the flame tube) face up unprotected, directly under the grill cooking surface they tend to get blocked quickly with continous use and certain foods, like pork ribs. Bad design unless all you plan on grilling is hot dogs.
There are about 500 individual holes, so plan on being there a while. Or in other words, do it close to the cooler.
I've been tempted to toss the thing into the woods a bunch of times over the past 2 years I've owned the dumb thing.
Apr 19, 2008 | Weber Q Grill
Weber Q Grill Logo
404 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
