Question about Acme 5001 Supreme Juicerator Juice Extractor
Motor runs and is seem like it has a clutch that is slipping. Tried the re-set button. The re-set button does not seem to engage anything. Took the 4 screws off the bottom but do not see anything that looks like an issue. Any advice or ideas ? Acme 5001
    Champion:
  • 356 Answers
The white impeller that you attached the basket and blade to is
keyed to the motor shaft. There is a small shallow nut that you
can remove with a needle nose pliers and pull the impeller off
the shaft to see if it's seated properly or damaged. If damaged
talk Waring into selling you another at 1 800 492 7464.
Posted on Apr 26, 2011
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Dash juicer wont turn on
Just fixed this problem!
Take bottom off juicer. The 4th screw is an "odd" one...I drilled the center out and used a flat head.
When you look up inside the juicer, you will see a silver lever arm. It touches the arm lock mechanism (so the juicer will only run when the arm is engaged).
The lever arm should be behind the black lever arm part on the side. When I opened mine up, the silver level arm was on top of the black post thingy. I took a screwdriver and pushed it off the black post thingy, so it the very bottom of the silver lever is behind it. (I can no longer see the entire silver lever easily when it is in the correct position.)
Totally fixed it.
I think it bounced out of the correct spot when I juiced some hard veggies or when I moved it, it hit the counter pretty hard.
Anyway, good luck....I am not a mechanic so sorry if the language is non-technical.
Oct 05, 2012 | Juicers
A small slice of cabbage got stuck at the bottom of the funnel where the vegetable goes onto the blade. The motor stopped immediately and is now not working. This same mishap happened about a year ago...
A small piece of cabbage should not stop this machine. If it did stop, look for the red reset
button on the bottom of the juicer. I've been using mine for 21 years and occasionally it will
stop when run for an extended period especially if vibration is present. In each case I waited
a few minutes and pushed in the reset button.
Mar 29, 2011 | Acme 6001 Juice Extractor
Not sure how to assemble juiceman jr juicer,
Model #JM01C K: The motor works. The black start button works. The on-off Switch does not engage with the start button when moved up and down. Am I missing a part?
Dale
dale@webr4m.com
Jan 03, 2011 | Salton Jr. JM1 Juicer
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
It will not turn on, i tried the reset button still no power. How do i fix it?
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Jul 11, 2009 | Jack Lalanne Power Juicer (Stainless...
I cannot remove the blade and screen from my Jack Lalanne juicer......saw mention of the cresent tool which I did not get.........can anyone help?..........SW
Wear leather gloves or double rubber gloves. Hold on right on top of the sharp blades and turn it. You can also bend a 1/8 th inch diameter thick wire, galvanized or anything metal and insert both ends on the holes on the blades and turn it. Make sure you don't slip your hands on the sharp blades.
Jan 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
Acme 5001 on / off button
REMOVE THE 4 BOTTOM SCREWS AND
TRY IT AGAIN. YOU CAN SEE THE SEAM
AROUND THE JUICER WHERE IT SEPARATES.
YOU CAN GET THE SWITCH FROM WARING
AT 800 492 7464. MINE IS FROM 1990 AND
RUNS LIKE NEW. DO ALL MY OWN REPAIRS.
Mar 10, 2008 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
74 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
