Question about Intermatic Hardware & Accessories
RE: Intermatic model T8845PV used for a sprinkler system. The system works fine on manuel but does not come on on the days selected when on automatic. Day pin is pulled out and aligned with 12 0r 14 arrow. Yesteday, Saturday, the system ran on automatic but it was set for Sat and Sunday. Today is Sunday, the pay pin is pulled out for Sunday but it did not run. Thanks. Jack Williams Coral Sjprings, FL 954-341-9831 wms33076@bellsouth.net
1) Check that yellow timer dial is rotating and keeping correct time > if not, then buy new clock motor
2) Check that silver tripper pin is installed at 12 midnight. This tripper advances day-skipper wheel each day at midnight. Check that tripper is advancing the skipper wheel.
3) Rotate skipper counter-clockwise until current day lines up with 14 arrow.
4) Check gold tripper pins are pushed in place.
Open following links for parts list
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/pdf/Setting-Intermatic-sprinkler-timer.pdf
Posted on Apr 08, 2011
How to connect my well pump to timer
T8845PV has 120 volt input.... but 24Volt output,
You can use 24 volt to control contactor that can be used to switch 120-240 volt pump
Wiring on following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Dec 02, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
T8845pv
You have 120Volt Intermatic sprinkler timer with 24Volt output.
Copy following link for setting sprinkler timer:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Copy following link for wiring Intermatic sprinkler timer:
Add a comment
lllllllllllll
May 25, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
On auto mode sprinkler start sometimes out of the time zone
Maybe the trippers are worn out??
Add a comment and give model number of product, and say if this is new installation or older installation that stopped working recently.
May 05, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
Im trying to change out my automatic sprikler timer, the new one is Intermatic model T8845PV. Its an old house I have two hot wires going in to the old timer, and I only see one spot for my hot wire in the...
Open following links for resources:
http://waterheatertimer.org/images/T8845PV-image-700.jpg
If you have 2 hot wires, then you have 240Volt circuit from breaker box.
T8845PV is 120Volt timer.
How to wire for 120Volt: Use one hot wire to connect to LINE terminal. Cap off other hot wire. Then connect bare ground wire to terminal marked NEUTRAL.
This is not code, but it will work until you have time to run 120Volt line from nearby 120Volt outlet.
Read about 120 and 240Volt circuits
http://waterheatertimer.org/B220C.html
T8845PV is 120Volt timer, made to control 24Volt sprinkler valve.
Inside the timer, there are two wiring terminals marked LINE and NEUTRAL
120Volt cable from circuit breaker has black hot wire and white neutral wire.
Connect black hot to terminal marked LINE
Connect white neutral to terminal marked NEUTRAL
The yellow wires are 24Volt output.
Yellow wires connect to sprinkler valve.
Do not connect 120Volt to yellow wires.
This timer does not have terminals for rain sensor:
Jul 31, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
The time works, but SOLENOID does not come on - the SOLENOID was working prior, but the timer was not working, was able to put on manual, but that does not happen now - i have the two yellow wires from the...
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
http://waterheatertimer.org/pdf/Intermatic-t8845pv.pdf
T8845PV has 2 yellow wires for 24Volt output that powers solenoid.
1) Yes the yellow wires connect to two wires on solenoid.
2) 120Volt power arrives from breaker box. Black hot wire connects to Line terminal screw. White neutral connects to Neutral terminal screw. Check for 120Volts across both terminal screws.
3) Next check that output on yellows wires is 24Volts. The manual does not specify if that is 24Volt AC or DC. I assume that means it is AC. Buy cheap multimeter at home center to check 24Volt output.
4) Tests from 2) and 3) will tell you if 120V circuit is problem or if transformer has gone bod or if solenoid is suspect.
5) T8845PV uses T8845PV transformer, but it might be cheaper buying whole new timer and then snapping new mechanism into existing box
http://www.1000bulbs.com/product/3422/ELEC-T8845PV.html
Apr 21, 2011 | Intermatic T8845PV - Sprinkler-Irrigation...
How do I install a T8845pv sprinkler timer. What do I attach to the two yellow wires
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
The timer is used to power a low-voltage sprinkler solenoid valve.
A solenoid is an electrical switch that opens and closes a gas line or water line.
The yellow wires go to your sprinkler system solenoid valve.
The solenoid is the valve that turns water on-and-off.
The 120Volt electric cable that runs the timer connects to the Line and Neutral terminals.
Black to Line terminal, white to neutral terminal
The clock repeats each 24 hours.
Lift and rotate dial until current time lines up with silver pointer
The skipper wheel has pins >> press pin down for each day you do not want watering
Rotate skipper wheel counterclockwise until current day lines up with 14 arrow
Put tripper pins on yellow dial
Each pin represents 12 minutes of watering
To water for 48 minutes, put in 4 consecutive pins
Put pins on wheel at the time you want watering to take place.
To water twice a day, put pins at two different times, and do not put any pins between those times.
Oct 28, 2010 | Intermatic T8845PV - Sprinkler-Irrigation...
Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
May 09, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
197 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
