Question about Dryers
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
  • 11 more comments
  • Kbrad Oct 07, 2008
    whirlpool duet dryer error code E1
    can someone assist in what to check for?
    karen.bradford@mckesson.com
  • Anonymous Mar 13, 2009
    My whirlpool dryer stops running and displays the E1 error code.
    plrmo3@aol.com
  • Anonymous Apr 02, 2009
    dryer displays this message and stops running. It is always overheated
  • Anonymous Apr 11, 2009
    E1 code turns off dryer Please help
  • Anonymous May 19, 2009
    erratic drying and E1 code sometimes appears gew9200
  • rosalinda_ta May 19, 2009
    rosalinda_tan71@yahoo.com My Dryer runs then stops with error code E1. What's wrong?
  • jfrankha11 Nov 29, 2013
    I got same problem on a whirlpool sensoron Dryer, the E1 code. send fix information thanks
  • Anonymous Mar 16, 2014
    My dryer will not turn on and oesnt display an error code
    Error message F 01
    Whirlpool duet error codes
    Error messages
    Dryer error message F01
  • Anonymous Mar 30, 2014
    Wont run. Light come on but get an error code of 0F1. Cant find what this code means. Its a whirlpool duet electric dryer and is like a 2008 or 2007
  • 770 Answers
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
  • 1 more comment
  • michellebaus Nov 22, 2010
    Master Tech - Are you still on this things? I have the E1 code as well!!!! I see that this posting is from 2 years ago so hopefully this alerts your with an email. Can you email those wonderful steps that everyone else was asking for?
  • susan Jul 16, 2012
    was wondering if the instructions you speak of are posted somewhere......I have the E1 code and would like to fix iit.....phook101@yahooo.com
  • Mweeks
    Mweeks Jun 01, 2014
    Ok HELP weeksmarisa5@gmail.com
Got the same problem! Would you email me info@thevictorianinnblowingrock.com
Thanks
Posted on Jul 09, 2011
  • Jeff
    Jeff Apr 27, 2014
    Got the same problem! Would you email me @ jamklein@cfu.net. Thanks! Jeff Klein
  • Kachuty May 30, 2011
    getting the same E1 error code with my dryer plzz help me ;-) i have my little 1 pushing the boton 4 me (poor kid)
Master_Tech:
I am getting the same E1 error code with my dryer as well. Could you please email me the steps to fix?
Thanks!
jessicapchamberlain@gmail.com
Posted on Nov 09, 2009
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 25, 2010 | Kenmore HE5
Whirlpool Duet dryer runs for 1 min. and then shuts off with e1 error, I did some research and found out their is a thermal fuse located behind the lower panel. Also something about a the heater could be...
E1 error code is a problem with the thermister sensor is is located behind the lower front panel..you do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Aug 22, 2010 | Whirlpool GEW9200L Electric Dryer
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet error code e1
Whirlpool Duet E1 Error
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 02, 2010 | Whirlpool GGW9200L Gas Dryer
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool duet dryer shuts off and E1 code shows
E1 is an open thermistor. The thermistor lives on top of the blower housing. Get to it by removing the bottom quarter panel.Does the E1 error represent failure of the thermistor,
The quarter panel is right there in front, down at the bottom, below the door. Look closely and you'll see two screws. Remove them and the panel comes right off. Some pics at this link:
http://fixitnow.com/2005/03/appliance-repair-revelation-peek.htm
hope this helps.thanks and Godbless .appreciate by rating as fixyaa
Oct 17, 2008 | Dryers
Dryers Logo
2,349 people viewed this question
Top Dryers Experts
