Question about HP Mini 1000 Netbook
Amps and volts of hp1000 adapter or charger - HP Mini 1000 Netbook
  • 54 Answers
19V 1.58A,30W
Posted on Apr 11, 2011
I would like to charge my 930 T on 120 volt A C adapter
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Oct 18, 2015 - Read this guide on finding the right charger or power adapter. ... As part of that process, I took all my power supplies and adapters and threw them into a box. ...from a 120 V AC outlet in your home) and convert it to a specific DC output. ... Voltage is measured in volts (V) and current is measured in amps (A).
Is there a way to charge my 930 T on a wall socket AC adapter
www.fixya.com/.../t26037021-way_charge_930_t_wall_socket_ac_adap...
24 mins ago - is there a way to charge my 930 T on a wall socket AC adapter - PC Laptops ... I would like to charge my 930 T on 120 volt A C adapter. Jan 03 ...
AC versus DC charging - what is the difference? ' Plug In ...
www.pluginamerica.org > Blogs > Drivers Seat
Plug In AmericaOct 13, 2013 - It is simply a USB cable, which allows my tablet to charge from a DC USB ... When you plug in to AC power - whether you plug in to a 120V or .... 120vphone chargers and plugging in to 74 volts DC and charging their phones.
Jan 03, 2016 | Computers & Internet
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Jan 25, 2013 | Computers & Internet
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
I have an Augen netbook and though fully charging the battery, the indicator says it's only half charged once I disconnect the charger. I need to fix this, if possible as I bought it on sale and thre are...
Recommend you compare the Volt & Amp reading on both the A/C adapter & Netbook.
The Volt & Amps will be on the underside of the netbook.
The Volt & Amps will be listed on the A/C adapter (wall charger).
Compare the numbers:
Example: 19Volts / 3.9 Amps
These numbers SHOULD match between the netbook & A/C adapter.
Apr 04, 2011 | Computers & Internet
My cauzin Got Acer Aspire 5920 !! its charger stop working she buy another charger for it !! but due to inexperience she bought 24 volts instead of 18 volts !! after charging some time the laptop isn't...
One of two things. The Power Connector (on the motherboard) or the motherboard itself. If it is just the power connector, you can purchase a new one for around $10 (look at the specs for your model) and solder a new one on. If it is the motherboard, you'll be replacing alot more than it most likely. It could have fried the GPU, memory and Proc.
And the following three condition should be met for you to use an AC Adapter safely.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Specification of Acer Aspire 5920 Charger:
Output: DC19V 3.42A
DC Connecter (Barrel) size:
Internal Diameter: 1.5mm
External Diameter: 5.5mm
Feb 22, 2011 | Acer Computers & Internet
Can a nx9110 charger /ac adapter work on an ibm thinkpad t30
Thefollowing three conditions should be met for you to use a charger safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop. Pleasecheck carefully before using nx9110 adapter on t30.
Dec 11, 2010 | IBM ThinkPad T30 2366 Notebook
I can't find the series # of my note book---- where can i get a replacement charger?
Any charger which fits the following conditions will be a good fit to your laptop:
1. Charger has a jack which fits in the laptop's power socket.
2. Charger can provide enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the charger. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Alternatively, you can look for a universal laptop charger which is suitable for your laptop's model.
Aug 28, 2010 | Acer Aspire One PC Notebook
I lost the AC adapter for my Vector Compact Elite 300 amp jumpstarter (veco11). What output adapter should I use to charge it? I have a 12 volt that doesn't seem to work.
You need about 14 volts to charge a 12 volt battery. The original charger MAY have some form of current limiting in it.
ALSO pay attention to the polarity of the charger.
Oct 30, 2009 | Electrical Supplies
HP Mini 1000 Netbook Logo
20 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
