Question about Wizoo Darbuka
Hi, I have a problem, Latigo Wizoo crash Cubase 5 I can not open the latigo on cubase5, Thank you to help resolve this problem. I work with windows xp Thank you Kinde regards, Antonio Portugal
Music recording on HP ProBook 4510s would it work ?
does it need fixing? this is fixya not your personal assistant,,
Jul 29, 2015 | HP ProBook 4510s Notebook
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I need a manual for cubase 5
Found this on the web. you can download the zip file and get the manual.
Cubase 5 Manual Download Here
http://www.cubendo.com/showthread.php?t=354
If this information is helpful, please rate me.
Thanks and Good Luck : 0)
Dec 09, 2009 | Total Training Cubase 4 The Essentials...
Problem installing wizoo darbuka
after instaalation
STEP 1 IN THE PROGRAM SETUP OPTION I DID PUT MY CODE NO
STEP 2 CERTIFY ON LINE (REQUIRED) SHOULD TAKE ME TO THE WEB TO CERTIFY DRBUKA (her error web).
then the program in front of me does't work just view.
Apr 02, 2009 | Wizoo Darbuka
Security key -defect
i lost my cubase activation key and code coming new york can some help me please thank you for your time
Sep 19, 2008 | Steinberg Cubase Recording Software...
Vista Home Premium fails to work correctly with 3rd party audio-ware, even though ALL audio product Vista drivers updated, and Vista OS software updated. Apparently the Vista audio problem is a common...
you will have a very hard time finding drivers for xp. dell will not support and dell does not have drivers for xp for your system. try vista sp1. i have no problems with my 1530
Aug 11, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Jun 21, 2008 | Steinberg Cubase SE
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Computers & Internet Logo
259 people viewed this question
Top Wizoo Computers & Internet Experts
David Payne
David Payne
Are you a Wizoo Computer and Internet Expert? Answer questions, earn points and help others
