Question about Panasonic Lumix DMC-FZ50K Digital Camera
When I fit the radio transmitter module from a set of Jianisi PT-04TM wireless flash slaves to the FZ50 it will no longer select all settings of apeture and speed. With the camera on manual setting the apeture freezes on f4 and the fastest speed available is 1/250. radio transmitter wasn't allowing flash to open fully, as it projected out over flash popup. I tried fitting an extension to mount radio transmitter higher and allow flash to open fully but still the same problem Fitting a normal flash unit didn't give the same problem. (wasn't game to put batteries in the flash unit in case the trigger voltage was too high). The wireless units don't give the same problem on a Ricoh digital camera I have. Is there a menu setting which will overcome the problem? Thanks Paul
  • peugeotlife Apr 11, 2011
    Thanks Trimast, I managed to find the same solution Googling shortly after I posted the question.
    Some studio work down the track but at present using the camera and flash for nature/wildlife photography. Idea is to have one small flash close to camera and larger unit hand held away from camera on other side. Sourcing a TTL flash with remote sensor to use as main flash. Hopefully a Sunpak 555, dedicated coupler cord ext-11 and Olympus module will work. Failing that I will use Sunpak 611 on auto setting, with the remote sensor fired by optical slave unit in front of lumix flash. Small flash also on auto but one stop wider fired by a second slave. As you say I need to read the manual. Thanks for the link.
    Thanks for the reply, very helpful.
    Paul
  • 747 Answers
I've looked through the PDF manual for this camera and found the flash system pretty well full auto with the built in flash here is the manual link I used it's the fifth one from the top.
http://www.google.ca/#hl=en&biw=1303&bih=818&q=panasonic+lumix+dmc-fz50k+PDF+Manual&aq=f&aqi=&aql=&oq=&fp=a5556ef3492e88b9
You will need to do some extensive reading on the used of an external flash and you are right don't put other then what is recommended into the hot shoe for an external flash due to trigger voltage.
That said you need to select the external flash switch from built in to external. Next thing is once you switch from built in to external for use with a wireless transmitter everything becomes or will become manual. You will loose the ability to TTL because there is no communication between the trigger unit and the camera everything will be manual.
It sounds as if you are attempting to fire studio strobe lights.
In this case using wireless transmitter you will need to manual set your camera ISO, Shutter Speed and Aperture by doing light meter readings from your lights and setting your camera to those readings.
Or use dedicated external flash units. Even if you use a dedicated flash unit to trip the studio strobes the strobes will not synchronize with the camera flash.
Okay as a "rule of thumb" my studio lighting is set up to give me 1/60th shutter speed, F8 or F11 aperture at ISO 100.
You can't ask non designated flash unit to give you designated flash performance TTL because there is not communications between the flash units and the camera.
You need to read the manual on this camera and the external flash use
Posted on Apr 11, 2011
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Useing a flash off a sony a300
Obviously, you'd need a separate flash unit, since you can't take the built-in flash off the camera. Just as obviously, you'd need a way to trigger that flash.
Some flash units have a remote sensor that will respond to the camera's flash. The a300 has a wireless mode for triggering such flashes. There are remote flash systems that include a radio transmitter that fits onto the camera's hot shoe and a receiver that the flash mounts onto. Some flash units have a jack so you can use a cord to connect the flash to the camera.
The degree of automation depends on the system. The a300's wireless mode works best with Sony's own flash units. The separate wireless and cord methods will work with just about any flash, though you'll probably have to set the exposure and flash output yourself.
Jan 14, 2013 | Sony Alpha DSLR-A300 Digital Camera
Hello there. It seems that the Sigma EF-500
John, there is a difference in sync times between film and digital flash. It's taken the third party manufactures a little time to catch up so there is a lot of "film" flash units out there. I'm understanding that the Sigma flash doesn't fire at all which is pretty amazing I would have thought it would fire just not at the correct time. This flash isn't a total loss because it can be used wireless with a slave unit for fill or even a main light triggered from a mini transmitter on the camera hot shoe. Here is a link to an e-Bay auction to see what I'm saying.
http://cgi.ebay.ca/Wireless-Flash-Trigger-Transmitter-Receiver-4-Canon-/230537528202?pt=Camera_Flash_Accessories&hash=item35ad1b838a
I use this type of system for a location shoot, there are no wires and I can set up and balance my lighting to each set with no more dark backgrounds hope this was a help
Oct 24, 2010 | Sigma EF-500 Super for Canon TTL Flash
I have a 2000 pontiac trans am. when i set my alarm my haedlight pop up. they never use to. replaced module,and headlight motors,still didn't fix it.
In your owners manual on pages 2-19 and 2-21 tells you how to change this.
Entering Programming Mode
1. Turn the ignition key to RUN, then to OFF. This will
disarm the content theft-deterrent/alarm system
(if equipped).
2. Remove the RADIO fuse. This fuse is located in the
main fuse block which is located on the left side of
your instrument panel. The radio fuse is on the lower
right-hand corner of your instrument panel. See
"Fuses and Circuit Breakers" in the Index.
3. Turn the ignition key from OFF to RUN three times
quickly (within five seconds). The vehicle will
respond by locking the doors, unlocking the driver's
door and releasing the hatch. Your transmitter is now
ready to match the vehicle. Leave the ignition
in RUN.
4. Press and hold the LOCK and UNLOCK buttons on
the first transmitter for 15 seconds. The vehicle will
respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your
transmitters, replace the RADIO fuse.
7. Check that all transmitters work by pressing
the buttons.
Programmable Modes
Your vehicle can be programmed to one of the
following modes:
Mode 1: All Off (The headlamps will not flash and the
horn will not sound to provide you feedback that a
lock/unlock command has been received by the remote
keyless entry transmitter.)
Mode 2: Horn and Lamps/Lamps (Your horn will sound
briefly and your parking lamps will flash when you
press LOCK on the remote keyless entry transmitter.
Only your parking lamps will flash when you press
UNLOCK.)
Mode 3: Horn and Lamps (Your horn will sound briefly
and your parking lamps will flash every time you push
LOCK or UNLOCK.)
Mode 4: Lamps (Your parking lamps will flash every
time you press LOCK or UNLOCK.)
Mode 5: Lamps/Horn and Lamps/Lamps (Your lamps
will flash upon the first press on LOCK, your lamps will
flash and your horn will sound upon the second press
on LOCK and your lamps will flash upon any press
on UNLOCK.)
Vehicles are delivered programmed in Mode 5.
To change the mode, do the following:
1. Press the UNLOCK button on the remote keyless
entry transmitter.
2. Count the number of chimes you hear. The number
of chimes tells you which mode your vehicle is
set for.
3. Press the UNLOCK button, again, on the remote
keyless entry transmitter until you hear the number
of chimes that correspond to the mode selection
you want.
The mode you selected is now set. You can either exit
the programming mode by following the instructions
later in this section or program the next feature available
on your vehicle.
When programming is complete, turn the ignition to
OFF and reinstall the RADIO fuse.
Sep 20, 2010 | 2000 Pontiac Firebird
Hye! can we use umberella lights with this cemers kodak z612 ?
To use umbrella lights, you need a hotshoe connection on top of the camera to attach a radio transmitter. This would set off the umbrella lights. Some high-end DSLR cameras do this very well.
Sep 14, 2010 | Kodak EasyShare Z612 Digital Camera
Can I use it wirelessly with a canon EOS 40D
Yes you can but it won't TTL and you will need to fire it from or with a slave/light cell. This will make your system more like a studio set up. You will need to increase/decrease the light intensity using different modifiers for special effects. My portable/location set up uses 2 Vivitar 283's, a Canon 533G, Nikon SB 15 and a Canon 420 EX all fired from little flash slaves. here is an e-Bay reference link
http://cgi.ebay.ca/Flash-Slave-Trigger-Hot-Shoe-Sync-Adapter-Sensor-US-/110405132832?pt=LH_DefaultDomain_0&hash=item19b4a8a220
Hope this was a help
May 19, 2010 | Canon Speedlite 540EZ TTL Flash
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
$150 wireless speaker
use a expanded module for input/output RCA ports, Radio Shack
Jun 15, 2008 | Brookstone Outdoor Wireless Speaker...
Slave Flash
I'm guessing you're talking about a wireless connection...
Unfortunately, the 430EX can only act as a slave. You'll need one of the following to act as a master control unit: 550EX, 580EX, 508EX II or the ST-E2 transmitter :-(
Matt
Feb 19, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Panasonic Lumix  DMC-FZ50K Digital Camera Logo
60 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
