Question about Onkyo TX-DS777
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it by changing cables but the problem still the same.
    Brigadier General:
  • 8,546 Answers
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Posted on Apr 03, 2011
  • 2 more comments
  • jun mango Apr 07, 2011
    Hi, thanks for the comments. It is a Samsung HT-Z210. The L/R Audio and Video-out is connected to the Onkyo TX-DS777's L/R Audio in and Video at the Video3 slot. The Onkyo's monitor out is connected to the Video-in of the Samsung TV. The TV displays the Onkyo's volume control movement indicator but no video image, no sound. The sound connection must be fine because the speakers sound good from the CD player connected to the Onkyo receiver. Joe, another wiz has suggested to connect the HT-Z210d to the Video 1 or 2 instead and then connect the Video 1 or 2 out of the Onkyo to the TV instead of the monitor out. The Samsung HT-Z210 has the HDMI but not used with the Onkyo Receiver. I welcome another option to solve this connection. I will work on the system this weekend. Thanks.
  • David Dunn
    David Dunn Apr 07, 2011
    I still see no audio path from anything to the TV in your scheme. Monitor Out is just composite video. Testifying to the sound integrity by using CD as an example is irrelevant as it is NOT originating at the HT and it is not passing through the receiver, but terminates there.
    The intent is still unclear. Are you using the HT as a DVD source through the Onkyo to the TV? Where's the HDMI going? Have you considered traking it straight to the TV? The video will be much better and it WILL carry audio, too. You seem to by tying the DVD player down to standard composite video and 2-channel analog sound. The HT is NOT designed to be the multichannel sound source for anything but itself and a TV.
    Depending on your TV, you MAY be able to pull digital audio out from it (after the DVD player sends it there via HDMI) so you can hear it through the Onkyo.
    As I implied before, unnamed pieces shed no light on this scenario.
    OK your point on the monitor out to TV has nothing to do with the audio is well taken. I just can't remember but I thought the audio is connected to the Samsung but this I will check again this weekend when I get back to the system.
    Yes, the intention is to use the HT as a DVD source through the Onkyo to the TV. We wanted to use the Onkyo sound system to power the movies played via the HT on to the TV. Since the Onkyo has no HDMI, there was no intention to use it. Yes, the HT worked with the Samsung TV via the HDMI. I will try as suggested to re-connect the HT HDMI to the TV and then I will see if I can pull digital audio out of the TV to the Onkyo.
    All I have in the system is the Onkyo TX-DS777, HT-Z210, set of speakers connected to the Onkyo - NHT L/R Front Speakers, Center Speaker, PSB L/R Rear speakers, Solid Subwoofer, Onkyo DV-525 DVD player, Onkyo multi-CD player. The set of small HT-Z210 surround speakers are not intended to be used at this time.
  • David Dunn
    As I said, the Samsung is NOT intended to export its audio to anywhere better than itself. A decent DVD player is very cheap these days. Or invest in BluRay and REALLY enjoy the video.
SOURCE:
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
Digital In on Samsung HT-Z310 no sound
Optical into your XBOX 360? If there is a connector that you are using to convert it, I was start by replacing that.
Jun 04, 2010 | Samsung HT-Z310T Theater System
Connecting Sirus audio to Onkyo HT-R500
Carl- If you are sending a Line Level Audio signal to your ONKYO RECEVER, from your Sirus RCA cable Output, IE, the CD input, the VCR input, the AUX in, ETC. No Need to have the RECEIVER in the FM mode, you are just needing amplificaton of the sound signal or Sirus signal sound.
Feb 28, 2009 | Onkyo HTR500 Receiver
Hello and thank you in advance for helping me resolve this.... i have a insignia 52 flat screen tv.... i just installed a samsung ht z310 home theater... i tried everything and i cant seem to get the sound...
have you connected the optical cable. as the only way to get sound from the tv to the surround is via that link. the hdmi cable only send video and audio to the tv not both ways for some reason.
Jan 20, 2009 | Samsung HT-Z310T Theater System
Samsung ht-z310 home theatre audio problem
All,
I submitted an earlier request trying to determine why surround sound wasn't coming through all speakers when playing my TV.
Looking further into the Samsung site I found out that you MUST connect the optical cable from the home theater unit to the CABLE BOX and not to your TV to get surround sound...I'm currently in the office but will change the connection once home...try connecting to your CABLE BOX instead of your TV and it should resolve the problem.
Oct 02, 2008 | Samsung HT-Z310T Theater System
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Connecting a Samsung HT-Z310 home cinema to a Series 5 Samsung TV and Games consoles, will only work with DVD currently. How do I get the cinema system to work for TV and consoles?
Do you have an Optical Audio cable going from the A/V receiver to the TV? If not, you need to get one. Since the HT-Z310 only has HDMI output and no input there is not audio bypass. Once you connect an Optical Audio cable from the receiver to the TV, anything that goes through the TV (cable audio, PS3 or Xbox 360, DVDs, Radio) will go through the receiver, too.
May 28, 2008 | Televison & Video
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-DS777 Logo
267 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
