Question about Miele Washing Machines
Miele type woshing machin ws 5320 elreplacing axle bearings and watertight drum
  • 4,323 Answers
Hi
Please check this video, it would help---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 03, 2011
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Miele type woshing machin ws Problem
Hi
If you are replacing the bearing, which I won't recommend but still you can check this video on how it's done:
Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 04, 2011
Miele Touch Tropic 9800. Why is it making a loud grinding noise?
Hi dear. Regarding your information,it's a dryer. Most likely it has bearing damaged or problem with drum drive system. There are several bearings on the dryer (one at the back- two on the front support, tension pulley etc...) I can advised to get it check by Miele. Thanks.
Apr 10, 2016 | Miele Washing Machines
How to change a drum bearing on a w806
Go on you tube and type it in. I have found many there that help me step by step video
Dec 07, 2014 | Miele Washing Machines
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
1999 plymouth breeze. step on brakes and the front brakes have a bad pulsing to them. previous owner hab brakes done rotars turned and pads replaced. any suggestions on how to address this problem
Symptom: Brake Pedal Pulsates Change When: Braking Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Brake Drum Specs Brake Drum Out of Adjustment, Out of Round, or Cracked. 2 Inspect Brake Drum Unevenly Worn or Out of Round Brake Drum(s). 3 Inspect Brake Rotor Incorrectly Machined Brake Rotor. 4 Inspect Wheel Bearing-Front Incorrectly Tightened or Installed Wheel Bearing. 5 Inspect Wheel Bearing-Rear Incorrectly Tightened or Installed Wheel Bearing. 6 Inspect Wheel Nut Loose, Worn, or Damaged Wheel Nut(s). 7 Inspect Rear Axle Bent Rear Axle.
Apr 13, 2013 | Plymouth Breeze Cars & Trucks
W113 washer drum is loose inside
I had the same problem. I stripped my machine down when they told me it would cost 1200.00 to replace the bearing. I found out after taking it apart it wasn't the bearing. It was the bearing shaft assembly shaft mounting bracket that is made of cast aluminum and the metal was corroded beyond repair. I called Miele and you have to buy the whole inner tub assembly 517.00 plus tax and shipping. I will also replace the bearings as well.
Jan 08, 2012 | Indesit WA 115 Front Load Washer
Our washer makes a loud banging noise when it is on spin cycle, and the drum feels loose. What would the problem be? Can I fix it myself? Is it worth repairing?
Unfortunately it sounds like you may have a broken drum bearing. They are not very easy to replace and I would recommend using a professional if you are not sure about what you're doing. It is quite important to get the seals watertight again, and this can be quite tricky. I suggest you get a quote for repairs and see if you might not be better off getting a new washer.
Jul 24, 2011 | Frigidaire ATF6000ES Front Load Washer
How do i change rear wheel bearings on 2001 dodge ram with drum brakes
im pretty sure the whel bearings are sealed and pressed on to the axle. in which case you need to take the axles to a machine shop.
Jan 29, 2011 | Dodge Ram 1500 Cars & Trucks
I'm looking for a service manual for Miele WS 5425 washing machine, any ideas where i can obtain one?
i have a Miele ws 5425. it wil not open even though though the cycle has finished. It still full of water. The red fault light flashes on the drain symbol.
Jun 17, 2010 | Miele Washing Machines
Grinding noise on drivers side rear axle bearing
Remove the wheel and check the brake shoes/pads and the drum/rotor. If they are both fine, then you'll have to remove the axle and check the bearing. To do this, remove the retaining bolts on the plate just underneath the end of the axle where the tires mounts. You may need a slide hammer or axle puller to get the axle out, especially if the bearing has deteriated substantially. Once you get the axle out you'll have to take it to a parts store or machine shop and have the old one pressed off and the new one pressed on.Driving them off or on with a hammer can damage the axle where the bearing seats or the new bearing. If the bearing has seized, check to make sure it hasn't damaged or scored the bearing seat inside the rear end housing.
May 25, 2010 | 1999 Ford Expedition
Miele WS5426 Heater Element Replacement
On the WS 5426 the elements are mounted at the bottom of the drum of the accessed by opening the front of the machine.
Removal of the elements will involve destroying the rubber seal and can be done by cutting two vertical slots with a sharp knife in the seal and then pulling hard on the seal with a pair of pliers. It is not necessary to remove the spring clamps or drip shield but it will aid access to the seal.
Mar 11, 2008 | Miele Washing Machines
Washing Machines Logo
134 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
