Question about Yamaha RX-V463 Receiver
Code ck sr tuner no sound - Yamaha RX-V463 Receiver
    Top Expert:
  • Yamaha Master
  • 75,311 Answers
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Posted on Apr 03, 2011
How can I connect an equalizer to my Marantz sr-66 ?
Does it have a loop through connection that is before the amplifier section of the tuner? If not I'm not sure you can. If so then you need to connect the equalizer in this section of the tuner.
The owners manual should be able to tell you more than I can find on Google
Oct 07, 2014 | Marantz Sr-66 Audio Video Surround...
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
Where on a car can i get information about tank capacity
the operators guide has it.
and varies by country.
and engine options
and other options.
why not just fill it up from empty, and guess.
if car is USA, is it?
and you know whats on the car, engine size and type. and if 2wd or 4wd and other things, SR 5 and other options.
the login to alldata.com
but for free, you can go to any seller of any tanks and see this.
on 91 they had 5 major option packages. SR5 with V6 too.
the base 4 banger shows 17 and 19 gallon here.
see it?
http://www.rockauto.com/catalog/raframecatalog.php?ck[mkt_US]=true&ck[mkt_EU]=true&ck[mkt_CA]=true&ck[mkt_MX]=false&ck[year_1994]=true&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=kmn2mr0latem2ta7d7s59vvgk2
spectra premium can be seen on line and checked for size.
Jan 21, 2014 | 1991 Toyota Pickup
Hi, i have a acoustic guitar but i do not know how to tune it with the Matrix Chromatic Tuner SR-1050
That tuner has a built in microphone to listen for your guitars sound. Turn it on and set is close to your guitar as you tune it.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Hello, I am inquiring about a replacement antenna for my Polk Audio SR H1000 Sirius satellite tuner. Thank you, Donna Sebran
It sounds like you should be able to find a replacement antenna from any of your local electronics retailers, such as Best Buy, Radio Shack, etc. I would take your old antenna with you when you go to look for a replacement, though, to make sure that the plug that is on the end of the new antenna looks exactly like the plug on the old antenna, to be sure that it'll work for your needs.
Oct 17, 2010 | Polk Audio SR-H1000 SIRIUS Radio Receiver
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Jul 13, 2010 | Yamaha RX-V663 Receiver
Samsung SR-30NMA refrigerator compartment not cold enough. Freezer compartment OK.
ck that your fans are working and clean the condenser coils . this will help / if ice build up in back of freezer it also could have a defrost problem . blocking air flow .. ck these and if more help is needed get back with me **** ..
Jan 04, 2010 | Refrigerators
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
TX SR-702 Sound Problems
please check your system with a new cables fist .and check that the input is assigned to your media(sound or video)
Apr 06, 2008 | Audio Players & Recorders
Driver in windows XP
Use this guide:
http://www.jvcpro.co.uk/getResource2/install_sr-dvm70.pdf?id=6345
It's for a different model, but it works the same.
In a nutshell, when the "AV/C Tuner" driver request comes up, just cancel the install. Then, it will want an "AV/C Tape Recorder/Player" driver. It "should" install automatically and be instantly recognized. If not, follow the instructions in the guide.
There are also instructions in there for disabling the "Av/C Tuner" every time the deck gets connected. Hope this helps - worked for me! - cliffpro.com
Feb 20, 2008 | JVC SR-DVM600
Yamaha RX-V463 Receiver Logo
383 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
