Question about Samsung HT-Z310T Theater System
When i turn it on it sais protect and shots down. thanks
  • Samsung Master
  • 2,098 Answers
Hi sita72,
Protect is an error code for short and or overload. This will appear once the processor sense a malfunction either on the power supply or on the load (high chance is the output IC). DIY steps are as follow to determine where the fault is : 1. Allow the unit to cool down for an hour. Give proper ventilation and keep away all obstruction from the vent to have a sufficient air flow. 2. Disconnect one at a time the speakers, inputs, from the unit while powering it on.
If the unit back to normal again then you've confirmed that any of the above caused the error code. If #1 is the caused, you have to check also the exhaust fan, clean it as much as possible, replaced if faulty. If #2 is the caused (speaker) check the wire and speakers for short, (input) check the RCA cord for short or replaced if necessary.
If the above simple fix didn't cure the error code, you can try the next steps if you are an electronics enthusiast. Now after removing the cover, you have to concentrate first on the power supply board. Look for bulged electrolytic capacitor. Leaky capacitor will affect the regulation of the supply and will trigger the error code. Look for dry joints. Check it also in the pre-amplifier stage, main output board where a big heat sink is located. Next disable the output amplifier stage by disconnecting the supply. If the unit come out, make some re-soldering on the board, spot the cold solder and dry joints and then try to connect again. If the error code appear again, high chance that your output IC is faulty but still to be confirmed. Using the disoldering pump and soldering iron pull-out the output IC from the board then try the unit. If the error code disappear, confirmed that your IC is faulty.After trying the abovesteps-by-steps guide and still the symptoms persist this is the time for you to send it to repair shop. Remember that your unit has a lot of parts and only some basic steps have done, leave the expert to troubleshoot the entire unit.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 03, 2011
When take picture in normal mode or 1x/ 2x zoom the picture clarity and sharpness is very good.but when i take picture in 3x/4x optical zoom ,picture clarity and sharpness is very poor..my camera i cannon...
Turn on auto focus and when you are taking a shot let Auto-Focus adjust the blurry image in the viewfinder beforeyou take a shot. If you do not know how to do it please let me know and I will give you detailed instructions.
Sai.
May 16, 2011 | Canon PowerShot A570 IS Digital Camera
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
How to unsecure movie on chip, so that it can be erased
It's not so obvious, but unprotecting is done in the same way as protecting. View the movie, press MENU, scroll down to PROTECT and doing it again will turn protection off.
Feb 03, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Excuse me this is my moms but she deosnt know cameras AT ALL , and im wondering how to take off the " protected momry card " settung in other words ,, i go to take a picture and it sais " this memory card...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 04, 2010 | Panasonic Lumix DMC-LC43 Digital Camera
How to turn protect off power shot s30.
You'll need to go into the review mode, hit menu, and then in the first category (top menu), scroll down to protect, and then hit "function set" to turn it off.
Sep 13, 2009 | Canon Cameras
My system shot down during a movie
The reason why your receiver is going in protect is because there is a short circuit happening. This would either be on your speaker wires, speakers or receiver itself. What you want to do to check would be:
1. Unhook all sources and speakers from your receiver.
2. Turn on your receiver and crank up the volume to maximum, if your receiver does not shutdown or go on protect then the receiver is OK. If it does shutdown and go on protect then its an internal problem on the receiver and you would need to send that over to an authorized service center.
3. Hook up a source and 1 speaker. Play something from the source or the fm tuner, Crank Up the volume to about 46 or 47 volume. If the receiver does not shutdown, its good.
4. Hook up a second speaker and repeat the process until you encounter the pop and shut down
if for example you encounter the pop on the 4th speaker, try changing the speaker wires.
5. If the receiver still shuts down then it would be a short on the speaker itself and it would need to go to an authorized service center.
Feb 23, 2009 | Onkyo HT-SR800 System
IM TRYING TO UNBLOCK XD CARD RIGHT PROTECTER
The card will have a small latch that can be slid up/down for locking or unlocking it. Move it to the opposite end to unlock the card..
Hope that helps,
Sai.
Jan 14, 2009 | Cameras
My sony cyber-shot DSC-W55 will not work!!!!!!!
It may be as simple as a dirty lens. If your lens is dirty it will act like it is out of focus and give you those messages. If it isn't that you want to repair it yourself. There is a guy in South Carolina who has lots of parts for all the Sony Cameras. I bought my LCD from him for $39.00 plus shipping and it works perfect. I put it in myself and saved a ton. If you buy the part from him he sends you pictures of him taking the camera apart so that you can repeat the process when you install it. I think his email is gerald.ray@aa-ark.com
Dec 28, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Erasing protected pics - Sony Cybershot dcs w-55
Formatting will erase all pictures, including protected images.
  1. Turn on the camera
  2. Press the menu button
  3. Press the "right" pad control button
  4. Then press the "down" to go to Setup (looks like a toolbox) then press "right" again
  5. Then arrow down to the Internal Memory Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
  6. or, if you have a memory stick where the image is, select memory Stick Tool and choose Format by pressing the Center Control Button in the middle of the Control Pad.
Hope this helps, if it does, please select FixYa! ThankYa!
Dec 05, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung HT-Z310T Theater System Logo
458 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
