Question about Century Welding Tools
Plasma cutter will not start - Century Welding Tools
    President:
  • 3,433 Answers
Hello;
Remove the copper cap and replace the tungsten button underneath it.
if it is concave it is too far in to start the arc and maintain.
The ground must be good
Good Luck -Ned_
Posted on Apr 03, 2011
I purchased a I60 Plasma cutter and I don't have an instructions manual. Can I download one?
Plasma Cutting Guide - Plasma Cutter Tips - The Eastwood ...
www.eastwood.com/plasma-cutting-guide-plasma-cutter-tips-plasma-cutt...
Check out Plasma Cutting Guide at Eastwood tech library to know about ... hasapproximately 25 amps of output, a 1/2" machine has a 50-60-amp output, while ...When buying a plasma cutter, the manufacturer should provide cutting .... Finally, follow all safety tips and guidelines that are detailed in your instruction manual.
How To Select And Operate A Hand-Held Plasma Cutter ...
https://www.millerwelds.com/.../how-to-select-and-operate-a-hand-held-...
The actual process of operating a hand-held air plasma cutter unit is relatively .... If you only have 115V primary service, don't worry. ... 50 or 60 Hz. This means you can plug this plasma cutter in anywhere in the world. ... If you opt to purchase such a unit, position it as far away from the particle ... Plasma Cutting Roller Guide.
Best Plasma Cutter Reviews 2015 - AIR TOOL GUY
Dec 27, 2015 | Welding Tools
I have a simadre cut50D an I don't have the ground cable can I still use it?
No. Check here for the specifics of how plasma cutters work: http://home.howstuffworks.com/plasma-cutter4.htm Without a ground cable, you cannot complete a circuit, and the physical basis of how a plasma cutter works doesn't function.
Sep 13, 2014 | Welding Tools
Simadre plasma cutter blows breakers as soon as you turn it on
WTF is a "tipo" ? YES your machine is defective.
Dec 27, 2013 | Welding Tools
Miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Mar 24, 2009 | Welding Tools
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters support
Plasma Arc cutting is an excellent choice for most cutting applications but it is particularly well suited for applications where speed and excellent cut quality are important. Because of the intense heat of the plasma arc – around 40,000° F compared to 5,700° F, with gases used with Oxy-Fuel torches – the cut is clean with little or no dross.
Aug 27, 2008 | Miller Spectrum 1000 Plasma Cutter...
Welding Tools Logo
154 people viewed this question
Top Century Welding Tools Experts
Bill Boyd
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
