Question about Shuttle MediaDock IS73/320 LVD (DIGI99001192800) Hard Drive
My warfedale is73 stereo powers up but not headphone or loud speaker output alll fuses ok any ideas. Not on mute. An address to send for repair please. Regards Nigel Bacon
  • Shuttle Master
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Apr 03, 2011
Headphone jack in tv has stopped working when putting speakers or headphones in is making a loud clicking sound. Is there anyway to connect speakers or headphones to the tv without using this jack? Have...
What type of TV, IE: Make and Model. If you have a SCART socket, then you can probably use the audio output connections on the SCART cable to connect to your stereo.
One thing to check is that your TV isn't muted! I know it sounds silly, but lots of people have inadvertently muted their TV's and not realized it.
Nov 14, 2017 | Electronics - Others
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Hi, my sys was working fine then 2 cables of one of the speakers came off by accident and now I can't get any sound at all to any ok the speakers I plug all right but I only get sound al the headphones...
Some of the new systems have a separate headphone amplifier chip. In that case when your wires came off , they must have shorted a second damaging the output amplifier. The protection circuit turns on disabling both the channels . On Sony systems a warning display comes on and the stereo goes to standby mode till the fault is fixed .
Mar 08, 2011 | JVC HX-GD8 CD Shelf System
The speaker connected to my Yamaha EMX 312 SC is not bringing out any sound when we use the microphones but the displays on the power mix shows there is activity.
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
Feb 10, 2011 | Yamaha Emx312sc 12 Channel Stereo Powered...
CAN U USE EXTERNAL SPEAKERS FOR A PC OR IPOD DEVICE ON A TELEVISION THAT IS JUST NOT LOUD ENOUGH
You can only connect speakers that are amplified in some way. most tvs will have analogue (red and white) stereo output which you would normally connect to an amp and then to the speakers. Your only other option is if you are able to find PC speakers that have a 3.5mm stereo headphone jack that will fit into the headphone output on the tv (if it has one). once again, the pc speakers will need to be powered (amplified).
Oct 07, 2010 | Televison & Video
My RCA RS2622 sound stopped working.
I'll need to look up your specific model to be sure, but I believe that the speaker outputs come from an amp pac. The headphones are driven by an opamp IC. The outputs are blown on this. If you can solder, you should be able to repair this. I'll look up the parts required and get back to you.
Dan
Aug 29, 2008 | RCA Audio Players & Recorders
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Computers & Internet Logo
293 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
