Question about Kenmore Refrigerators
Coils in freezer are frosting up causing the refrigated part to warm up
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 03, 2011
The freezer is cold, the fridge is warm, and the fan in the back of the freezer is running.
Ya got 2 possible thing that will cause that
1) the damper in the upper left corner of the refrig.compartment is stuck closed so no cold air can enter from the freezer into the fresh food compartment,by placing your up to that damper their should be some (not a lot) of air flowing through it. If not it is stuck closed
2) its not defrosting in the freezer so the freezer coil where all cold air is made is totally one huge block of frost again causing air flow into the fresh food compartment to be cut off.Do you see frost build up on the back wall of the freezer?? if so this link describes what to check http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Aug 27, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
Our freezer and fridge or not keeping cold enough
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor or back of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Freezer is "frosting over...refrig part not cooling????
it sounds like the defrost system is not operating and getting rid of the frost. the common fault is that the defrost heater has gone, or the heater cut out has gone or the defrost timer is faulty. how is the door seal in the area- that can cause frosting with warm air ingress.
Mar 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Frigidaire side/side refri section warm
Oceanrunner, it looks like a couple of things might be going on: One is how much defrosting did you do. If it was a full defrost, you might have too many door openings going on. This causes condensation. Do a full defrost and then be sure the door is closed when not actually getting things in/out. Don't forget to check to see if your condenser coils are clean. If not, clean 'em! That may fix it.
It is possible that your defrost timer is defective but I think not based on your defrost cycle starting. It is possible that the defrost coil is bad. This means that you'll have to access the coil and check if for continuity. Typically, this is located with the coils and below them in the back of the freezer. One wire on each side. Unplug the box...Wiggle 'em to clear any corrosion... Unplug..If you've got a multimeter, check for about 100 ohms between the terminals...You can then turn the unit on and wait. See what happens. If frosting begins, actuate the defrost cycle. (Frosting should be even after about 5 minutes or so across they pipes. If the gas level is low, the frosting will not be even.)
Some cold water units run through the coils. If they get too cold...they freeze. This is caused by low gas or by frosting from other sources. Don't panic: this unit has an extended warranty on the sealed unit...the compressor and all that...for 5 years. That means the gas, too. Call your manufacturer for service.
Nov 28, 2007 | Refrigerators
Confused /
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
