Question about Bose Cinemate Digital Home Theater System Speaker
Bose speaker make a makes only a humming/buzzing sound when I put it on. How can I fix this?
4 Suggested Answers
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
bronk50
  • 27725 Answers
SOURCE: get loud hum from both
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 23, 2011
SOURCE: The left speaker of my
This may sound strange, but try slipping a piece of cotton on the area where the bare conductor runs through the plastic covering of the speaker (as suggested here). 39c682c9-7c92-4e14-963e-7b6eb35c074d.jpg
Posted on Oct 22, 2013
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
Mackie dl1608 and Bose l1 humming
This sounds like a ground loop.
Make sure that everything in your signal chain (mixer and anything that plugs into the mixer, and the L1®) are all plugged into the same power source (power bar).
More tips here:
Ground Loop Bose L1 Encyclopedia FAQ Wiki
Jul 11, 2013 | Audio Players & Recorders
Get loud hum from both bose companion II speakers when i disconnect left speaker hum goes away tried most everything else thanks
hope this helps
May 23, 2011 | Bose Companion II Computer Speakers
I have a bose wave radio fo many years, when turn it on there is a constant buzz as the radio plays. the buzz varies if i move or position the radio differently. sounds antenna related but there is no...
The antenna is built in. The buzz you're hearing is a 60cycle hum (electricity from a nearby appliance) Try this, put an extension cord on it and walk it around your listening room for best reception. You can also find the culprit appliance by turning items off 1 by 1 until buzz subsides.
Jan 04, 2011 | Bose Wave Radio
Left speaker has developed a hum. Checked connections and all seems well. Sounds raspy like the speaker has blown.
This is likely due to a problem with the amplifier. You may have turned up the amp to the point of overdriving the speaker. The distortion at these high levels cause clipping and turn what was once crisp, clear sound into a muddied, garbled mess.
If the speaker is left connected to that source long enough, damage to the speaker and the amp may occur.
Without changing positions of the speakers: You can disconnect the affect Front or Rear L & R speakers and swap them (connect the L speaker to the R output of the amp and vice-versa). If the buzzing / hum "moves" to the other speaker, then the amplifier has the problem. If the buzzing / hum stays with the same speaker, the speaker has issues and is likely "blown".
Either way, it is probably not going to be a "cheap fix"
Jun 24, 2010 | Boston Acoustics VRS Micro Speaker
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Getting buzzing sound from speaker but can here sound from them.
You could have an earth loop which causes a hum/buzzing sound.
Is your computer and powered speakers plugged into different mains?
Connecting amplifiers and speakers to different power sockets will create earth loop problems
This can be fixed by using a single power board connected to a single mains power socket, then connecting all the computer components and powered speakers into this one power board.
Oct 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Subwoofer humming/buzzing
It sounds like one of the internal solder welds to the cable or a/v connections inside the cable box is bad.
Dec 19, 2008 | Bose Acoustimass 10 III System
Bose Cinemate Digital Home Theater System Speaker Logo
88 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
