Hi, I have an hotpoint wd640 washer/dryer that has stopped working had some assistance b4 but didn't solve the problem. There is power getting to machine,it was suggested the maine control board was gone,top right behind main switches/readout, but replaced this but know difference and power is getting to this as I had a shock off it any other suggestions thanx
  • 3 more comments
  • bruce Apr 03, 2011
    Machine just stopped working,no digital read out no power at the on off power sw but power appears to be getting to machine
    thanks
  • bruce Apr 06, 2011
    Hi kelly washer/dryer seems to have nothing no lights as if the power is off have replaced and tested plug fuse ok seems to be power in main cable and I recieved a shock off mcb any ideas thanx
    Hi Rich you find out any info
    Hi kelly washer/dryer appears to have no power no lights nothing but have checked plug fuse and there seems to be power in cable and machine
  • 3,740 Answers
What are your symptoms Please that got you a main board replace response?
There are several things than can cause a no-responsive control panel or inproperly funtioning washing machine:
1. Door switch / Listen for a click as the door just closes or opens. No click = bad switch
2. Child lock (Press and hold chil lock for more than 3 seconds)
3. Suds Sensor coated with debris (Behind filter remove filter / reach in and clean)
4. Filter (Remove and clean_
Codes:
F05 (filter error / clogged filter)
or
F11 (Pump can not be activated / Bad pump or PBC-Main board error)
The information in your post this time does not really give me enough information to properly respond.
Kelly
Posted on Apr 04, 2011
  • Kelly
    Kelly Apr 06, 2011
    The main board has a transformer on it that provides low voltage AC outputs into diodes to make DC for the Display and Control functions. A knowledgeable person has to be able to locate the transformer outputs and verify the low voltage AC outputs of the transformer and the DC voltage after the diodes. The transformers fail and then everything about the machine control is dead. Here is the kicker.... These units also have a motor control board and if the currently installed motor control board is bad and you install a new MAIN PCB and<- it can fail in minutes! Since you have no lights no display the only thing that comes to mind would be to check thermistors. You said you got a shock from the Main PCB so I doubt the thermistor is bad..
    DOES the DOOR SWITCH click at all? No Click.. and this can cause your symptom. (micro-switch type click as door is just opened or closed)
    I know this is not the answer you wanted to hear but it is the best I can do from here to explain what is happening with your machine.
    Kelly
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What exactly is the problem that you are having?
Posted on Apr 03, 2011
  • Richard Roth
    Richard Roth Apr 03, 2011
    Ok, let me see what info I have on that. I will post back shortly.
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF640 - What is Fault code F01 please?
My list for nearly all of the Indesit (Hotpoint, Ariston) washers suggests there is a fault with the motor triac, the bit that controls the motor speed, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 10, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the...
hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
As this wd640 is a washer dryer, im sure there must be a filter some where I need to clean etc but dont know how to find it or go about it.... Had a manual but cant find it... thanks Elaine
Hi.
Yes there is a filter.
Remove lower rear panel of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump, check for obstruction or blockage here, and look inside the pump as well.
This should solve your problem.
Nov 30, 2009 | Hotpoint Aquarius WD640 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd640 replacement motor brushes
machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Jun 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
