Question about True TSSU-60-16-ADA Stainless Steel Commercial Refrigerator
I have a true tssu-60-16 keeps freezing up. I checked the condenser and it is clean any other ideas? Thanks
  • 17,970 Answers
Make sure the evaporator fan is running, and that it's rotating correctly. You may have to melt the ice off the evaporator first.
Make sure the coil is clean, and that the drain line is clear. If only the first section of evaporator piping is freezing up, you very likely have a low charge, or possibly a restricted drier, liquid line, or metering device.
Check your pressures, temperatures, superheat, and subcooling.
In this link could find to check the "Air Conditioning and Refrigeration System Evaluation Guide" (without test).
Hope this helps.
Posted on Apr 03, 2011
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
I got a true tssu-27 that won't cool what would be the problem with this unit?
Many times the air circulation across the condenser is the problem. Take a look at the condenser and make sure that the condenser fan is running and there isn't dirt or grease blocking air movement. There is also the obvious like a compressor that's not running or an iced up cooling coil. Is the compressor hot? Maybe an additional description would help. Are the fans inside the cabinet running? Good luck hope this helps.
Oct 23, 2014 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
Why is the unit freezing? It is a TRUE TSSU-60-16.
Turn down the temp and move produce item closer to the front. The air exits the evaporator at around 28 degrees. Possible you need a thermostat.
Feb 04, 2013 | True TSSU-60-16-DS-ST-ADA Dual Sided...
TSSU4812 refregirator making clicking sound and not cooling
Without a compressor analizer you will need to check the winding
resistance. or you can just cross your fingers and hope the relay
and start capacitor are the problem. Sounds like the condenser coil was plugged so you could possibly have a locked up compresor.I doubt it is low on refrigerant charge.
Jan 15, 2013 | True TSSU-48-12-ADA Sandwich/Salad Unit,...
The vent that airs the cooler is freezing causing the cooler not to maintain the right temp. I have unplugged the cooler over night to let it thaw out and reduced the temp. dial. It worked, but then soon...
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 29, 2011 | True Sandwich Unit - TSSU-48-10
My True sandwich unit has been going up in temp slowly for the last month. It is set to the coldest setting, and is holding temp around 46 degrees now. It goes up around a degree a day. Any idea what...
first place to look would be the freon level. It sounds like there is a slow leak and freon level is going down. Start there and let me know if I can help any further.
Feb 14, 2011 | True Sandwich Unit - TSSU-48-10
Unit freezing up
as a former cook
do not line the bottom with foil
and clean the vents in the back
Oct 03, 2009 | True Sandwich Unit - TSSU-27-12M-C
Refrigerator keeps freezing up
check the door gaskets on the unit they could be leetting in too much moisture and that will cause the unit to form too much ice,
Mar 26, 2009 | True TSSU-27-12M-B Commercial Refrigerator
True TSSU-60-16-ADA Stainless Steel Commercial Refrigerator Logo
150 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
