Question about Whirlpool Refrigerators
There is water driping from the back of the refrigerater inside. Seems to coming from the unite on the top. Pools of water form on the shelf. What is the problem?
    Master:
  • 414 Answers
A couple of thoughts. First unplug the refrigerator and remove the back panel in the
freezer compartment and check the drain hole in the freezer. You will have to unplug
the fan and in some cases remove it to unplug it (Be very careful doing this).
you can use a turkey baster with warm water to check its operation. If the control
panel in the fresh food compartment extends to the back of the refrigerator, then
it also acts as the catch cup and may have a clog in it. Remove the control
panel (4 screws usually) and lower the panel slightly,
unplug it carefully slide it downward and out towards you and look for
clog in the catch cup and inspect the mating seal on the styrofoam as these were
often the culprit as well. (I usually dried them out with a hair dryer on low and siliconed
the mating surfaces on the earlier design that were styrofoam only with kitchen and
bath silicone for a better seal). Test drain with a turkey baster and listen for it
trickling into bottom tray. Then reassemble.
Posted on Apr 03, 2011
Why do i have to empty the water out every 2 hours 14000 btu portable plus humidifier aitconditioner 14200 btu heat pump
That is normal for a portable a/c unit if it has a drain on it you can put it on a shelf or counter and allow it to drain to a floor drain or sink. some newer units come with a pump to remove the condensate, this is the water you normaly see driping out of the a/c units in windows
Jul 21, 2011 | Soleus Heating & Cooling
Water leaking from my refrigerator
seems to be a condensation proble, is it possible to lower down fridge temperature a bit? This may solve the problem.
Mar 19, 2008 | Refrigerators
Jenn-Air refrigerator, top freezer, older model, frost-free. Ice has started forming on the "ledge" at the back wall where the lowest shelf rests. Then the ice melts and water pools at the...
There is probably a little sediment in the ice maker shut off valve. It's electrically operated whenever the icemaker starts a new batch.
You can try cleaning the valve, but it's typically not worth the trouble. I'd just install a new one. It's easy, typically just a couple screws, an electrical connection and the water connection. To prevent it from happening again, add an in-line filter BEFORE the ice maker.
Jan 31, 2011 | Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Water is leaking from refrigerator forming pools of water on floor.
You need to pay attention where the water is coming from. If the water comes from doors, look for magnet seal broken or spills from the inside the fridge. If the water comes from the bottom (or back) of the unit, it may be an installation issue.
Once you locate the source, it will be easy to fix.
May 08, 2010 | Refrigerators
Water driping inside from ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Sep 26, 2009 | GE Profile Arctica Stainless Steel Top...
Water driping on top shelfe from freezer,
The drain most likely was blocked by food debris and the water from defrost cycle had no where to go...unplug refridge...chip some of the ice along the bottom carefully or use heat gun to melt ice...when the tube becomes exposed put some hot water in the drip pan..this should help the ice melt in the drain tube....use a straw or curtain wire to clear blockage...you should see the water suddenly drain down tube...put everything back together...this is not a temp issue but more a blockage issue.
Jun 23, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I have a Kenmore Elite top freezer refrigator. Water is driping or somehow forming on the top shelves [under the top freezer] and a thin layer of ice will appear and the water contuniues to form. then over...
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 02, 2009 | Kenmore Refrigerators
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
