Question about EZ Dupe Magic DVD/CD Thermal & Cartridges Printer
After installing the software I try to us the Magic Printer, and I plug up the power, and then plug it into the USB port. Immediately I get an error message "USB Device not recognized." I do not know if this is a software problem or a hardware problem. I have removed the software from my computer (XP home), and then reinstalled it, but to no avail.
  • deweyhtucker Apr 03, 2011
    That did not work. It still gives the error message when I plug printer into the computers USB port. I've tried 3 different ports. What's next? The Printer is new, and my computer has all the requirements need for the printer. I have service pack 3 for windows xp.
  • 2,632 Answers
Welcome to Fixya. Since you already installed the driver and tried all the usb ports of the computer and you mentioned that the pronter is new i just need to ask you a simple steps to fix the issue.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be rebooted also because something can go wrong, i.e. all your USB ports suddenly stop working.
The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices. So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky USB device not recognized Windows error.
Please let me know what happen. Thanks for using Fixya.
Posted on Apr 03, 2011
  • Rofel Lantican
    Rofel Lantican Apr 03, 2011
    Have you tried to use the device to a different computer so that we will be able to determine if the problem is the computer or the printer. I hope that you know that sometimes even a new deivce can be defective.
  • 3,530 Answers
Welcome to Fixya
Try to restart your computer first after installing software or installing hardwares. Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices. So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Please get back to me if you have further questions.
Thank you for using Fixya!
  • Jose Cada
    Jose Cada Apr 03, 2011
    have you tried using this printer with other computer ans let see if you will be getting the same thing.
Windows 7--64 bit. USB port, was working. Had power outage due to lightning striking corner of house, burned out some breakers. Printer was on surge protector, but printer and PC not powered off prior to...
See if printer will work in another working computer. If it does the issue is with your computer hardware/software. If it also does not work then the issue is with the printer. And if so, it is not cost effective to repair given the price of printers these days.
Mar 03, 2017 | Brother MFC495CW AllInOne InkJet Printer
Need magic Jack plus software download
Magicjack software is stored in the Magicjack module. Plug that module into a USB port on your computer. You should get an onscreen message like: "Install or run program from your media".
Click on "Start Magicjack". That will install the software on your computer.
More information at:
http://www.magicjack.com/how-it-works.html
Jul 29, 2012 | magicJack Two, 2 Magic Jack Plus Voip...
USB port unplugged now won't print. Printer is online and ready. Comes w/ an error message.
Try unpluging the power once, if that doesn't work. Plug the usb back into computer and try updating the Printers Software. There may be a stand alone procedure that was never installed.
Good Luck!
Sep 15, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp PSC2355 scan function inop
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq9
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Communication problem printer lexmark2600
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 12, 2009 | Lexmark X4530 InkJet Printer
Unable to print
To fix a fouled install :
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Printer install problem
hi friend
u have to do this
1.plge in ur usb printer cable on other port
2.do not on ur printer
3 put ur printer cd in ur cd rom drive
4install ur printer software
5 in between the installtion ask to u power on ur printer then u have to on ur printer
5 completing the printer installtion
try to print
& thnx uing fixya
Mar 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Computer will not completely read cd.
When you say it will not install do you mean the software stopped during install? Did windows not see the printer? With your computer running. Connecting everything for the printer. Connect the usb cable to pc & printer. Last thing to connect should be the power. When you connect the power cord & turn on the printer. Windows should show an icon by the clock. This icon is windows found new hardware. If this does not come up than your printer is either not connected correctly, you have a bad usb cable or usb port is not seeing the connection. Try another usb port. Each company has their own way to install printer software. Most want the printer shut off. During the install of printer software, a window will open and ask you to connect the printers usb or serial connector to pc & turn on power. The software will finish. Others want you to install the software completely into windows. When you shut down windows than you hook up the printer & power. If everything above failed you can try connecting the printer to another computer & you can try another printer for your Dell. I know, who has something extra like a printer you pc but this is all about trial and error.
Hope one of these suggestions work for you! Lastly, new Dell! You should have free support through dell even for things like this. Luck!!
Please vote...
map
Jan 30, 2008 | Lexmark X1150 All-In-One InkJet Printer
"Off-line" error message
Go to control panel - printers. Right click your printer icon - select delete printer. Reinstall the software and drivers via CD supplied. May have to restart your computer when complete. Go back to control panel - select printers - select add a printer and follow the instructions. When finished print a test page.
Sep 13, 2006 | Lexmark X83 All-In-One InkJet Printer
EZ Dupe Magic DVD/CD Thermal & Cartridges Printer Logo
56 people viewed this question
Top EZ Dupe Office Equipment & Supplies Experts
jasbo
jasbo
Are you an EZ Dupe Office Equipment and Supply Expert? Answer questions, earn points and help others
