There is a fuse on the power supply board it says to only replace with ame fuse i understand that do i have to soder it out and in or is it more easily replaced.
    Scholar:
  • 90 Answers
Hi there, if in case on your TV that the fuse is needed to solder out before it can be removed, yes you need to solder it out. But if it has this fuse terminals that you only need to tap it out better if thats the case. Some TV has this fuse terminal for easy access in replacing the fuse. if still needed to solder the fuse I suggest that do a little rewiring and put a fuse holder if available, if just solder the new fuse as is the same as the old one. hope this help, please rate and vote. good day
Posted on Apr 03, 2011
Sylvania lc195sl9a no power only led blink
my tv was in ame condition i replace the board BA8AFOGO4017 and tv turn on
Mar 05, 2013 | Sylvania A8AN2UH Digital Board...
Standby power failure
If warrantee still good get new one if not check for broken solder joint on transistor works until it gets hot may need new transistor should have numbers on it., If to hot will need schematic. first get sodering iron and soder 60/40 remove all covers, get(freeze it) a can of cold spray and keep hands away from power supply board the board with the wall plug coming out of it and the thick wires connected to it. do not touch, Plug it in the wall and wait until it turns off, spray the componets that you think are the problem the cold will allow it to turn on for a while check the transistors first (little black box with three leggs) then the capacitors (the little blue barrels with the black lines on them) when you find the componet call the company for the replacement part find the manufacturing company on the internet they will have it.simply make a drawing of the way the componet was in the curcuit and put the new one in,tip on how to soder pull the soder off the roll about five inches, Place the hot tip on the leg and the board wait a second and drop the soder on the hot tip for just one more second, letting a small amount melt off.do this on each leg remember that a transistor has a ground,a hot, and a base,The cap has only a positive and a negative.Good luck
Aug 26, 2012 | Denon AVR-2308 AV RECEIVER 220 Volts-19407
Phillip 50PF9630A/37. I have a red blinking 7 times after a green light. i've allready replaced the 2 bulging cap on the bottom of power supply board and also a cap on the Y board (board on the left)...
Hello sir Jose!!!!
try to unplug the y sustain only and power ON your TV..and see what happen next..
Please reply to this tread for immediate help..
Feb 20, 2012 | Philips Televison & Video
I have a Sony Bravia 32 inch, storm came thru and now it wont turn on, and the lights on front will not light up, where inside is the fuses, i opened it up, i see fuses, can i pull it out or is it sodered...
There is a fuse in the power supply board near the end of the board.The tv power supply board is it dead.That the board where the power a/c cord plug in.Power surge by a storm,change the fuse will not help the board to work.Because all those ICS on a power supply board are very sensitive to electrical static charges are dead already.Tries websites like Shopjimmy.com,Ebay.com to buy a whloe new refurbish power supply board for the replacement.
Jun 30, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I HAVE A 32" VIZIO LCD I PURCHASED 2 YEARS AGO.
You should buy a sodering kit and remove the buldging capacitors yourself. Find a local electronics store, I used Radioshack, and see if they can match the capacitors. I had this happen with my Samsung lcd about a year ago and just help another friend with the same issue yesterday. The sodering is not as hard as you'd think. The capacitors should be under $5 v. paying a few hundred for the power board.
Mar 21, 2011 | Vizio VOJ320F1A 32 in. LCD TV
I have a Samsung 40" lcd model LN40A53OP1FX2A
Could be,might not also,any things on the power supply board could be burn and dies,when it getting to much electricity current to it.Dead or dying capacitors on the power supply board are alway bulges or puffing up on it tops.Check the power supply board carefully look at all the capacitors parts,if require replacing,u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braid,a roll of solders,also u must know basic soldering understand basic electronic to do it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Samsung LN40A530 40 in. LCD TV
MAKES A CLICKING SOUND WHEN I TURN IT ON AND TAKES ABOUT 20 SECONDS BEFORE THE PICTURE COMES ON.
This is power supply board problems,have dying parts call capcitors.Not giving the voltage anymore.That the board,where the power a/c plug into it.U have tools like a soldering iron,desoldering pump,soders.Can do basic soldering and know basic electronic.Check the power supply board for those dying capacitors,they alway bulges up on it tops or puffing up on it tops.Replaced these dying capacitors,tv will power up correctly and quickly.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 15, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Flat Panel Emerson Tv lc32oem82s
Answer your first question. yes, it is the same part.
To help you with the second question I need some info.
1. Do you have a multimeter?
2. A sodering gun with new soder and soder removal braid?
3. Sodering skills on circuit boards?
Jan 26, 2009 | Emerson EWL3706 37 in. LCD Television
MY tV will not power and red light keeps blinking
i had the same problem with my tv i got a sodering gun its the board like the power supply open the tv and look on the board and look for ic801 on the bottom of the tv board then look in box line it has numbers from 1-7 get a sodering gun then soder number 4 i tryd it it worked on the board but be care full it will mess up quick if your not i had the same problem with this tv the soder on the board probly came off on no.4 but after your done and you have to pick the tv up becareful and do it slow because number 4 might come off again then you have to do it again and if that aint it just look on the bottom of the board and make shore nothing is loose and use the sodering gun to put back on that should be it ok then
Dec 19, 2007 | Panasonic CT-32SL14 32" TV
Televison & Video Logo
378 people viewed this question
Top Televison & Video Experts
Electro Med Services...
