Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How do i connect my berhinge xenyx1002 to my amplifier can I use the lines in direct
  • Behringer Master
  • 5,603 Answers
You probablly can, but use BALANCED cables TRS or XLR. You haven't told us what amp so I can't be more definitive.
Posted on Apr 03, 2011
  • Ray Faccini Apr 09, 2011
    I wish to connect my berhinger xenyx 1002 fx mixer to a carlsbro cobra 1504 amp, I want to run 2 vhf radio mics 2 uhf radio mics 5 lead mics and a c d player. I am looking for idiot proof help as I know very little about this equipment, we are a small theatre group working for charity.
    Thank you in advance for any help you can give
  • Fred Yearian Apr 09, 2011
    The connections to do this are MESSY and not user friendly. The problem is you have only a total of 6 connectors for lead mics with the XLR connectors. You have to sacrifice one of those to run the out of the mixer into the cobra. Not only that, the control of the lead mics are in two different units. This will drive the sound man nuts. The radio mics if they all are independent outputs will have to go into the line inputs of the Xenyx. This is really messy as you BARELY have enough resources. The out of the mixer needs to connect to one of the precious inputs of the Cobra.
How do I set Connect my Boss ME 30 effects peddle .I have a berhinger xeney mixer .Do I need two amps
Try using the insert in/out for the channel you want or the main insert in/out for all channels
Dec 11, 2014 | Boss Music
Foot switch appears to be wired backwards. The Shape pedal turns on the UtraBass and the UltraBass pedal turns on the Shape (Channel 2).
Foot pedals are usually NOT interchangeable... The correct footswitch would come with the amp so be sure it says Behringer on on the footswitch. Apparently some sellers have foisted off VOX footswitches which may not work with the Berhinger.
Sep 16, 2011 | Behringer Ultrabass BXL3000 Bass Guitar...
I have the old 3way 600 watt pa speakers x 2,which amp would you suggest, for this speakers.Because I m having trouble with my amps,that keep on clipping and burning out.
DO NOT run amps into clipping. Also, while the speakers are rated at 600 Watts, you don't want to use an amp that delivers that much RMS. Use about 300 Watts per side. Unfortunately you did not mention the brand of amps you are using. I will also caution you that the speakers have protection networks that if you are getting supersonic feedback that you can't hear that can burn out the amps. DO NOT boost the highs if the mics can "hear" the speakers or the reverberations from them. Solid connection of speaker cables is important. Intermittent connections can fry amplifiers... I won't go into the technical reason for this other than to say the amp's feedback circutis get confused when the load shifts.
You might also have the speakers checked since they can have an intermittent that is popping the amps. If you happen to be using BERHINGER PMP amps, please read my tip about the grounding hazard where the sleeve of channel A is hot and the tip the cold that I have in the Fixya tips.
Mar 25, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Berhinger acx 1000, power on, no sound amp not working, everything lights up on display but no sound or amplification
Just had the baby brother (ACX450) with this problem...opened the amp... screws from sides and or top (including 2 hidden under handle covers).
The power cable from the power transformer had come off the connector on the circuit board in spite of goo they had put on it. Put connector back on and secured the cable and works perfect,
Since your display lights, yours is likely a different problem. I have also seen similar ones that the cable to the speaker had been pulled off its connection on the circuit board, rendering no sound. See if you have sound at headphone jack. and if none, how about the preamp output jack? Note you will only hear the left side using earphones as these jacks are monaural.
Feb 06, 2011 | Behringer Ultracoustic Acx900 Acoustic...
How to in install the speakers to it
You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
Dec 29, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have Berhinger 1680s powered mixer I have 2 Mackie 350 V powered speakers Can I hook them up? How do I?
Thought I answered this. Using balanced TRS cables, connect the powered speakers to the Main L and R 1/4 inch jacks on the top of the unit.
Nov 27, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Im try'n to hook a ''Duel fex pro'' multiband sound enhancement processor model ex 220, to my berhinger xenyx 1222fx mixer?
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
Mar 23, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
141 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
