Question about Elna Quilter's Dream 6003Q
MY MACHINE SHOWS A STEP MOTOR FAULT-ZIG ZAG--IT IS A 6003. If the parts are available-can my hubby fix it -he is good with his hands ?
  • Elna Master
  • 1,129 Answers
Here is a link to the service manual for the 6003 http://www.arizonaexpressionz.com/elna_service/6003_service_manual.pdf - these manuals are written for trained technicians but it might give your husband an idea of what is involved before he decides whether he would tackle the repair.
If you are in the USA then you might be able to source parts from www.sewusa.com, www.sewingpartsonline.com or a local Elna dealer.
I've always been happy to take my Elna to my OSMG (Old sewing machine guy) Ken as he's worked on Elnas for 25 years and I appreciate his knowlege and experience with them.
Posted on Apr 13, 2011
Why does my singer sewing machine model 600 not sew a wide width zig zag stitch
If your small zig zag is off to one side of center, it means the lubrication has dried out and the mechanism is dragging. If you can remove the top (usually held in place by a few screws) you should see some parts that move on zig zag but not straight stitch. Warming the parts with a hair dryer will tend to loosen them, just be careful of any plastic parts. A little penetrating oil (like WD-40) will help get the snap back in your zig zag.
Remove the needle and work the needle bar from side to side while turning the hand wheel with the machine set to the widest stitch.
Oct 11, 2016 | Singer Sewing Machines
My jones sewing machine wont stitch straight just zig zag tried moving parts
Probably the zig-zag mechanism has seized from lack of oil/cleaning. Pick up fresh, good quality sewing machine oil or Tri-Flow Synthetic Lube and apply a couple drops every place where metal rubs against metal (including the zig-zag mechanism). Do NOT oil any rubber or leather parts (belts)!!!
Then apply heat from a handheld hairdryer. Repeat until it loosens.
Aug 15, 2016 | Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
When making buttonholes, the machine will not zig zag in reverse when doing the right side of the buttonhole.
1. Remove the top.
2. Clean the inside with carburetor cleaner and lubricate with sewing machine oil.
3. While After this move the stitch length back and forth from a long arm to the reverse mode. Rotate the hand wheel several times to lubricate all moving parts.
4. Place some rags under the pressure foot and watch if the rags will back up.
5. Remove the bottom of the machine.
6. Clean the bottom moving parts and lubricate.
7. Rotate the hand wheel and watch the feed dogs to see if everything is moving.
8. It is possible to notice a screw attached to the stitch length adjuster that will have to be tightened. This may require you to move other parts that are attached and apply pressure while doing this.
Apr 02, 2015 | Sewing Machines
Elna 6003
Check to see if your needle is bent.
Feb 06, 2013 | Elna Quilter's Dream 6003Q
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Step motor error
One of the stepper motors has failed. The machine has two stepper motors: one that moves the needle back and forth and one that moves the feed. Take it to your dealer for an estimate.
Apr 02, 2009 | Elna Quilter's Dream 6003Q
The zag part of zig zag won't work
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected.
sewman7
Jul 28, 2008 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
111 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
