Hi, our washing machine Siemens E14-46 is out of order now providing error message F:21. It started working as usual without any sign of problem however after 30 minutes of washing stopped the process. Please, can you help me here? Thank you in advance, Jan.
SOURCE: indesit w123 washing machine
hi had a similiar problem on a year old washing machine after 3 engineers later who 1..put in a new circuit board...did not work 2...put in a heating element ...did not work 3...techican engineer..put in a new motor and repalced air pressure switch...bingo did work if your drum is turning slowly and does not wash how very well you may find ur motor is getting worn out..a problem..?? b careful they r £90 so make sure its that b 4 u change it my machine started to fill then almost immedately emptied out..then tured off then i had the flashing lights hope this is some help to u
Posted on May 29, 2007
  • 209 Answers
SOURCE: aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Posted on Sep 14, 2007
aborcass
  • 2651 Answers
SOURCE: Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Posted on Apr 05, 2008
  • 4090 Answers
SOURCE: LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Posted on Aug 11, 2009
Testimonial: "Thanks!I've already tried &didn't work. As soon as water fills up, instead of start washing, it makes the high pitch sound and "LE" somes up.Oh No...!"
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
Feb 22, 2015 | Bosch Washing Machines
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
How to reset siemens washing machine?
what model of machine
F40-50 is usually something to do with the door lock interlock
Aug 30, 2014 | Siemens Washing Machines
L4 error message on my Kenmore top loading Oasis washing machine?
call 21-341-0097 maytag service with model number aval and i can help you. it is poss you will need a repairman out and we also come to homes in the dfw area and east of dallas. we are a service provider for whirlpool/maytag.
Dec 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
SIEMENS WM1000 model timer to be connected.Kindly provide
i have a Siemens washing machine there is washing problem in washing ,some noise r generate like as chunk and wash cycle is not run proper and all function is work properly (darpan jain 9827622024)
Jan 25, 2010 | Siemens Washing Machines
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
Washing Machines Logo
459 people viewed this question
Top Washing Machines Experts
