Signal and stand by lights contiually flash - Computers & Internet
  • graeme ian hunter Apr 03, 2011
    on laptop or on desktop computer?
  • 196 Answers
Its running ... any hpw if you cant to check hard drive simply do these steps as in picture
check both the boxes to repair your bad sectors and filke system ...
more over defregment each drive of your computer as well
do vote if it helps
Posted on Apr 03, 2011
I need to find the flasher relay for a grand marquis 2001 .does it has one? My turn signals wont work I can hear the sound but don't even flash
Yes, it does have a flasher, although it may be a combined unit with the hazard flashers relay. So you hear the clicking of the flasher relay? That seems to indicate the relay is working properly. Have you checked the bulbs and the turn signal fuse? Any turn signal bulbs light up anywhere, front or back?
How about your brake lights, do they work? Your car may have separate, stand alone turn signals in the rear, but many American cars use the same bulb and same filament on the bulb for the brake lights and turn signals. If your merc is like this and the brake lights work, then the bulb must be good.
Turn on the hazard flashers and see if all bulbs work and flash at each corner of the car. This would be the same bulb as for the turn signals. If they work, it could be a bad turn signal switch, may even be the flasher relay somehow malfunctioning, and in a few cases, a bad hazard switch can affect the turn signal switch. Check fuses and bulbs first. If you have any type of body control module that controls lights and other accessories, you may have to investigate that. I know I'm not being very helpful, just throwing out a few suggestions. Good luck.
May 21, 2012 | 2001 Mercury Grand Marquis
When I turn my saw on it surges from full power to almost no power. This happens contiually while running. I checked the motor brushes and they llok good.
It happens continually while cutting? If you try to cut some that the machine has no power to do the job it will stop.
If you look inside the motor and look if the motor has some burn on the cooper motor wiring?
Nov 06, 2010 | Ridgid Heavy Duty 10" Portable Table Saw...
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
I have conia tv plasma model CPDP4209 O picture or sound /stand bt light on and A relay clicking on and off contiually I think the problem is A power supply fauilt .part no LJ44-00133A ACE-W2 PSPF...
I have the same tv with the same problem. On close inspection I found a capacitor was leaking. Replacing the capacitor fixed the tv. The capacitor is a 10v 1000uf, it is about in the centre and toword the top of the power board. I hope this helps.
Rick
Jun 26, 2010 | Televison & Video
Visual ringer light contiual to blink after all message have been delete
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2010 | Uniden DECT 6.0 Cordless Phone ID
Turn on green light flashes
Count the flashes before a pause. A steady on is bad ground or loose igniter. 2 flashes is either low gas pressure, bad flame sensor, gas valve wires loose or bad ignitor. 3 flashes is a bad pressure switch, or blocked vent. 4 flashes is a bad roll-out switch or open contact. 5 flashes is bad wiring to gas valve or flame sensor, 6 flashes is either a bad control board or bad thermostat.
Oct 13, 2009 | Sterling RF75 Natural Gas Heater (75,000...
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Pioneer PDP-435PG
I buy receiver of the plasma pdp 435pd my e-mail it is sergiofleitas@yahoo.com.ar
Apr 20, 2008 | Televison & Video
Philips bsure sv1 projector
try plugin a computor or dvd in so it picks up a signal.
Dec 15, 2007 | Philips bSure SV1 Multimedia Projector
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
