I have a pretty old Panasonic SA-AK630. At some point I started having the following problem. Once the sound is turned up to a certain point, the speakers are cut off and only the subwoofer is working. This is solved by "restarting" the speakers by plugging headphones in and then out. The cut-off seems to be triggered by certain frequencies as the "threshold" level appears to be different for different types of music/film, but is always the same for a specific song. Additionally, this level seems to have gone down over time -- I can only play music really quietly now. Not sure if this is relevant, but the cables to the speakers are extended to 2--4 meters.
    Brigadier General:
  • 8,546 Answers
I think you're indicating a self-protection problem.
One or more speakers or amps could be going South on you.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 03, 2011
Testimonial: "It worked! Thank you so much! It appeared that one of the extended leads was shorted."
WHAT CAUSES THE READOUT TO BE VERY DIM ON PANASONIC SA-AK630
IF the lcd display is fading, the only thing that you can do is send it in to be serviced.
Dec 29, 2014 | Panasonic Audio Players & Recorders
Looking for an panasonic stereo system model# sc-ak630 new or used.
Please try your luck at the following link:
http://stores.ebay.com/SecondHand-Electronics
However it is ideal to search around the repair stores in your area to find one if you are lucky.
For new set log on to the Panasonic website.
Jul 23, 2011 | Panasonic SC-AK630 CD Shelf System
Panasonic CD Stereo System SA-AK122, the power lights on but no display...,cant open/operate.
Internal power regulator have failed. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 27, 2010 | Panasonic SC-AK630 CD Shelf System
Panasonic sa-ak630. i turn it on an display said f 61 an turns back off all in a matter of a second or two... wires are all good.. and even just left everything unhooked an still no help... manual said...
F61 is the shorthand for Panasonic machines to mean protect mode. See the link below for a generic explanation of protector. Specifically, in your machine, either the regulator IC has failed or the output amp IC has failed. In any case, the repair will not be cheap. The output IC costs between $75-$125 depending upon the specific IC.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Sep 06, 2010 | Panasonic SA-HE100 Receiver
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
Dont know how to stop the demo mode. Panasonic SA-AK630 stereo
Set the time via the remote control and this will stop the demo running every time you turn it off.
Jun 14, 2009 | Panasonic SC-AK630 CD Shelf System
My cd stereo system sa-ak630 wont come of demo mode what do i do
there is a button on the left side that says "-demo" on it. hold that button until it stops...
Jun 05, 2009 | Panasonic SC-AK630 CD Shelf System
Cant play to loud
I believe the solution (or at least the explanation) for this has already been posted on here:
http://www.fixya.com/support/t1336858-f61_error
Take care,
Rob
Mar 02, 2009 | Audio Players & Recorders
Panasonic Receiver SA-XR25
I thought it might be heat related, so I put a small battery operated fan behind the receiver, and voila, no more clicking. I just have to invest in rechargable batteries or an electric fan.
Jun 26, 2008 | Panasonic SA-XR25 Receiver
I have a panasonic sa-ak630 and it works and everything i just dont have any sound at all
I had the same stereo, I found that the issue you describe happens often under heavy use especially with the subwooferon max. Simply unplug the stereo unit from its power source for about a minute and plug it in and it should work again. Hope this helps.
Apr 01, 2008 | Panasonic Audio Players & Recorders
192 people viewed this question
 Grubhead
Grubhead
