Question about Ovens
After my handle broke off on my Electrolux/Voss Elk 817-1 oven i need to replace it with a new one. The issue seems though that the door is riveted together not screwed, so how do get it apart to replace the handle??
  • 213 Answers
SOURCE: replacing broken oven door handle
whats the model number?
Posted on Nov 21, 2007
hotuna
  • 288 Answers
SOURCE: Hotpoint range door doesn't unlock after the clean cycle.
It is possible that the lever has been bent somehow. If you can lift the top of the oven as if you were cleaning it. look at the lever mechanism, move it to the other position and push it back carefully, to bend it back. I have seen this happen a lot, people lean on the oven, the lever is in the open position and it is pushed a little bending it so when it is moved to close it doesn't go far enough to release it. I am assuming you have waited for the oven to cool down before you tried this first right?
Posted on Dec 06, 2007
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
ginko
  • 19396 Answers
SOURCE: broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Hi, I have a double oven electrolux icon model number e30ew8cgps6. I would like to tighten the handle but only see one screw on the right side and the are three plastic covers remaining and its but the...
Thank you for your post, Karen!
Typically the door of your Electrolux Icon wall oven has a lot of layers. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the replacement part is installed correctly to prevent future issues. I hope this information helps to some degree. -Matt
Oct 19, 2014 | Electrolux ICON 30 in. Double Wall Oven
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
Hi. The outer glass grill door has come away and smashed on the floor when going to open grill by the handle. Can't see that there were any screws in the bottom of this. Would they have been factory...
Sometimes the glass is bonded to the door (glued) which may be why you can't see any screws.
It seems as if you are going to need a new grill door complete.
Dec 30, 2009 | Electrolux EOG9330 Gas Double Oven
GE Advantium SCA1000DBB03 handle replacement
open door look at side there some are some screws remove them the outer door part will come off now don t be afraid to use screwdriver to help take it off good luck later
Apr 01, 2009 | GE SCA2001FSS Advantium Electric Single...
My electrolux oven outer glass door shattered
hi
if there is no holes for the handles the changes are you have the wrong door glass. the best thing to do is take back to where you got it from and get them to check it
Mar 19, 2009 | Ovens
Electrolux EOB944. How do you remove the Glass panel in oven door ?
Hi
to remove glass panel you need to open door abit on top of door is 2 screws. undo these but hold handle at same time so it doesnt fall . once scrwes are out prise apart a little bit the lift glass then it should be of . hope this helps
regards dan
Mar 19, 2009 | Electrolux Ovens
I need a bottom door for an electrolux edb876 double gas oven
You will have to get a replacement from the mfr. It is not very difficult to replace, but can be time consuming. First before you buy one, make sure the hinge is broken and not just loose from the frame.
Feb 03, 2009 | Electrolux Ovens
Removing Whirlpool oven door.
My whirpool ikea single oven door is broke can it be replaced
Jun 26, 2008 | Ovens
DOOR PROBLEM
I am not sure about your oven model.  I had a similar problem in my oven.  The hinges are riveted to the oven and can be fixed.
First remove the oven door - normally the door slides on to two prongs on either side and is screwed down.
Once the door is removed check the mechanism that holds the two prongs to the oven body.  Mine were held with stainless steel rivets that had worn out and became wobbly.  Cut the rivets and replace them with new ones.  You can get a rivet driver and the stainless steel rivets for under $20 at Home Depot.
Hope this works for you.
Oct 16, 2007 | Ovens
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
