The rope circular "pad" lining
    Genius:
  • 1,479 Answers
Can you post this under the correct heading please.
Posted on Apr 03, 2011
    Brigadier General:
  • 8,909 Answers
I would use a small amount of fire cement. Available from B+Q etc.
Assembly Manual
Nothing to assemble in this kit:
Product Description Universal tent assembly and repair tool kit
1 mallet with white rubber head
1 guy rope: 15 m , colour Grey/Black
1 guy rope tightener
6 adjustable fasteners for ropes: 3.8cm x 1.3cm x 0.4cm
4 round closed hook head, zinc plated steel stakes: 23cm x 3.9mm
4 standard zinc plated steel stakes: 27.5cm x 6.5mm
4 zinc plated steel stakes: 23cm x 2.0mm x 1mm
4 zinc plated steel stakes: 28cm x 2.0mm x 1mm
8 nylon/elastic rubber rings: 29cm x 0.4cm
2 self-adhesive pathces: 7.5cm x 0.55cm
Oct 30, 2013 | The Camping Equipment Company Universal...
The glass plate of my microwave BDMOS15-XE is not rotating. IT is sitting correctly and clean. Robyn
You may have to take it to an appliance repair shop as some turn tables are drive by a rubber belt underneath outside of the oven. It requires the removal of the outer case at the bottom to access this area.
Aug 01, 2013 | Saws
The pull rope to start my bolens bl150 weed eater broke and can't get the new one too wind up
You need to pretension the spring before installing. Easier to do this before attaching the line, but there is a technique (at least for larger engines) for adjusting spring tension with the line still on. If you need I can describe it for you or tell you where on youtube I saw a guy do this. That video was for a snowblower engine, but the technique worked on my chipper. I see no reason why it would not work on a smaller two stroke, assuming there is nothing wacky about the configuration. I would think that a recoil starter for a two stroke and a four stroke should all use the same principle,.
Sep 11, 2011 | Troy Bilt Tiller Bolens Swivel Post Pn...
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My electric aga has gone cold
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | AGA Six-Four A64DSI Dual Fuel Range
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Smokey ovens
Hi, yes, it is a pity that this occurs.
In my opinion, an oven only can smoke for the next reasons:
1 burning insulation.
in this case the oven will not work long, so I think it is not the
problem
2 there are foodrests in the oven
but as you clean the oven regulair, this also will not be the
source of the problem.
3 the methode of cleaning is the wrong one. This cooker has
selfcleaning ovens
here you can find the User Manual of the Masterchef 100DF
http://www.rayburn-web.co.uk/Prodin/UNITED%20KINGDOM%20and%20IRELAND/AGA/2.%20AGA%20Discontinued/Aga%20Masterchef%20Mk1/Masterchef%20Mk1%20100%20Dualfuel%20Manual%2005-06%20EINS%20514327.pdf
I hope this helps, Dik
Feb 15, 2018 | AGA Kitchen Ranges
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Computers & Internet Logo
David Payne
David Payne
