Question about Tomtom GPS
Unable to store map settings. file access error
  • 515 Answers
Posted on Aug 09, 2008
3 Suggested Answers
SOURCE: tom tom go 300 ''unable to store settings'' ''file access error'
Connect to PC
Find the TomTom using Windows Explorer "drive F:" or "removable disk F:" or similar
Right click
Properties
Tools
Error checking
"automatically fix file system errors"
Start
Ta Da! Well it worked for mine......
Posted on May 08, 2009
  • 58 Answers
SOURCE: File Access Error
Check the SD memory card. There is a slider on the side of the card for locking to enable read-only mode. This slide should be up to enable read/write mode
Posted on Jun 14, 2009
I downloaded a movie on my Samsung tablet from the play store and when I go to play the movie it keeps giving me the following error: There was a problem while playing [-110] touch to retry I retry but...
Error code 110 relates to being unable to download apps from the Play Store. Can you do this? I cannot see why it comes up when you try to play this movie, but it may be trying to verify your access rights with Google Play and not be able to do so for some reason
Another possibility assuming that your tablet plays other video files normally, is that the file you downloaded is corrupted in some way. Try downloading it again. If you get error 110 when tring to download, there is a problem with the Play Store access. This was a bug on some Samsung tablets. In some cases, clearing any email account set up on the tablet may provide a temporary fix
Oct 23, 2013 | Samsung N110-12P Notebook
I have lost all UK & Europe mapping - except for major roads. This was initially built in to unit. Have SD card for Australia & New Zealand - this works fine.
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
Hi,my dsi i set the internet is work yesteday now is no work is sho unable to obtain an IP address. check your access point settings.Error code:052010-1.Ples hel mi.
Hi
Please check whether the below point will be helpful.
  • The DHCP settings of the access point and DS dont appear to be compatible.
  • Please check the DHCP settings of your router and try again.
  • If you have multiple connection files saved to your DS the error message you received can help determine which connection file may be experiencing a problem you error code says problem with connection file 2 .Please check
Feb 28, 2011 | Computers & Internet
In attempting to unsuccessfully download maps on Garmin for a NUVI 255W, I am now receiving an error screen on my Garmin: No detailed maps found that support routing. The nuvi cannot be used without them....
Ok I had same problem. Copy the mapupdater .exe file to another computer with internet access. Connect your GPS and then run the updater file. This worked for me. Good luck
Apr 29, 2010 | Garmin nuvi 255W GPS Receiver
Error occur during compiling,unable to open a header file
The compiler is attempting to access the iostream header file and it either cannot find the file (not in the default location or it has been told to look in another location where it doesn't exist), or the file security is set so the current user does not have read access to the file.
Apr 15, 2009 | Computers & Internet
File Access Error
Jan 02, 2009 | Tomtom One XL GPS Receiver
Tom tom go 300 ''unable to store settings'' ''file access error'
You might have the switch on SD card set to "read only" , This would stop your tomtom being able to write to the SD card ... hence , " unable to store settings " message . .... OR ... the folder where your tomtom wants to store the settings is corrupted ( on your SD card ) so it can't store them.... or similarly , the file is corrupted on the SD card ( maybe the card is damaged ) so the existing file cannot be overwritten . Check out all these possibilities before suspecting any hardware fault on your tomtom ..... GOOD LUCK
Nov 24, 2008 | Tomtom GO 300 GPS Receiver
Authorware problem
Click on site below, it might be what you are looking for. http://support.plato.com/kb/tip.asp?psid=26778
Jan 22, 2007 | Dell Dimension 2300 PC Desktop
GPS Logo
940 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
