I NEED the instruction manual inm pdf form ASAP for the Grandmax Tweakers Mini-Boom Portable Speakers, Black SPKR-R1-BK-L01
  • 196 Answers
Its not available try on these no's and adress if you are in US
Y.C. Cable East Inc.
121 Ethel Rd West STE 5A
Piscataway, New Jersey
USA
888-276-GMAX
Posted on Apr 03, 2011
  • sheraz Gul Bar
    sheraz Gul Bar Apr 03, 2011
    http://downloadcenter.samsung.com/conten... its in french .. you can copy past and translate it in google translate
Using a remote how do you hook up Pro technique pt18 5.1 Channel surround receiver amplifier
I need to see the rear or know if this set has speaker outputs. If so, then 1st, place your speakers on the walls or floor where you want them to stay. (Attach the wires to them first.) The black wire, black stripe or silver colored is the negative side. Run all the wires to the back side of the amp. Allow enough slack to put the wire under the carpet or along the walls to be out of the way and concealed if possible. Make sure to use a thick gauge of wire. The thicker the better. The thin stuff is junk! If you go to Lowes or Home Depot to get the wire, it will cost less and it's the same thing! Don't waste your money on 'Monster Cables'. Just get 12 gauge spkr. wire and it'll be the same thing. 14 gauge is the typical gauge for powerful spkr. wire but 12 gauge is for those who want earth shattering, furniture moving bass. (Think about it. How much power can go thru a thin wire verses a thick wire?) Run that wire to the black connection of the speaker that corresponds to it's position in the room. (Left front spkr., right front spkr., left rear spkr., right rear spkr., front center spkr. or sub woofer spkr. Find the red & black connectors for each speaker on the amp and attach one of the two speakers wires (the one w/a black stripe or silver colored or totally black to black). And the other color wire for the same spkr. to the red connection of that spkr. on the amp. It's not hard. Take your time and think about it. It makes sense if you look at it one spkr. at a time. Hook up only one spkr. at a time. Before you know it, it'll be all hooked up and you'll say I did that?
Aug 17, 2017 | Audio Players & Recorders
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Dec 28, 2013 | Jensen cd-472-bk am/fm cd boom box
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
I need a manual for the black cherry portable high-speed UB 2.0 hard drive. The one I have is 160 GB. Thanks.
Here is the manual that covers all of the SimpleTech Signature Mini External USB 2.0 Hard Drives. This is a pdf document, so you may need to install Adobe Acrobat Reader if you don't already have it installed.
Hard Drive Manual
Regards,
Dan
Mar 05, 2011 | SimpleTech Signature Mini 320GB External...
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
I need a user manual for my sony psp how can I get one?
Try this link, it's on the left side in pdf form.
http://www.onlinefreeebooks.net/gadget-ebooks/sony/sony-playstation-portable-instruction-manual-psp-1001-pdf.html
Jun 30, 2010 | Video Game Consoles & Games
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
222 people viewed this question
jasbo
jasbo
