Hey, i have a gateway gm 5472. when i try to boot the computer up, firstly, i have no video or sound, the led power light does not come on, but the fams run. what could it be
  • 28 Answers
Unfortunately, this sounds like you may have some dead hardware, try unplugging everything from the motherboard, and only leave the cpu, one stick of ram, and plug the monitor into the on board port (remove the video card).
Now try to boot the pc.
If you have no luck, try the ram in a different slot, or try a different stick of ram.
If you still have no luck, try the cpu in another motherboard to find out if it is faulty.
If you can get your motherboard to boot with one stick of ram and the cpu in place, turn it off and start adding components one by one, booting up each time to find out which piece of hardware is causing the failure.
Posted on Apr 03, 2011
Gateway 5472 won't power up
You must register some sounds and usual noise from the case. If you consider that power supply works, try to unplug all unnesessary parts, and remain with CPU+Graphics+Memory. You are now closer to eliminate the current problem.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Apr 13, 2014 | Gateway GM5472 PC Desktop
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Hey, i have a gateway gm 5472. when i try to boot the computer up, firstly, i have no video or sound, the led power light does not come on, but the fams run. I have a MCP61PM-AM motherboard in it with Amd...
I would have suspected that your RAM needs to be removed, cleaned & then replaced which more often than not sorts out the problem you have described.
But since you mention the power LED not working, I suspect that you have a faulty power supply.
Try connecting a power supply from another working PC to see if this solves the problem.
If so, power supplies are relatively inexpensive & shouldn't set you back more than $20-$30 for a descent unit.
Best wishes,
Graemevm
Apr 03, 2011 | Gateway GM5472 PC Desktop
Gm 5472 won't turn on
This either an issue with the power supply or motherboard. The best way to test is to replace the power supply and try to power it on to see if it works.
Something else you can try is, unplug all cables from the PC, open the case and the plug only the power in, turn it on and check to see if the fans turn on. If the fans turn on then it's most likely an issue with the motherboard but the best way to test is to replace the power supply and test.
Hope this Helps
Mar 08, 2011 | Gateway GM5472 PC Desktop
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
Gateway MX3416 will not boot. LED light indicating that there is a battery is still on. Screen is black but the CD-ROM drive seems operational. Removing RAM and replacing did not help.
Does the Gateway appear to boot up but you do not get an image on the screen?
Does the power LED light up and does the hard disk LED flash as the Gateway boots up?
If so then the Gateway could have a back-light problem or the video card may be faulty.
To determine the exact fault, please click on this link and follow my instructions to determine the fault an possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 02, 2010 | Gateway MX3416 Notebook
Gateway boot problem
This mostly happens when your motherboard is bad or one of the memory modules is bad.
The led light comming on indicates your power pack is ok but a component is failing to start especially when the laptop stops at the first screen stage where the manufacturer names appears.
The steps needed to solve this kind of problem would require technical skills and physical inspection.
If you still have a waranty period then seek a free service repair from an authorized or certified gateway service centre at the nearest centre closest to you.
If your warranty has expired, i still advise taking your Laptop to the closest Gateway service centre.
May 21, 2009 | Gateway MT3705 Notebook
LCD MONITOR
check the power chords
Sep 26, 2008 | Gateway FPD1975W 19" LCD Monitor
Monitor powers down upin startup
you need a new video card. it is powering down becuase it is not reciving any signal from you computer. if you are useing onboard video (vga) get a pci video card if you are useing a pci card try puting it in a dfrent slot.
Dec 20, 2007 | Gateway 310S (2900621) PC Desktop
Computers & Internet Logo
David Payne
David Payne
