Question about Indesit W 123 Front Load Washer
Wixl123 does not drain after washing ? - Indesit W 123 Front Load Washer
    Problem Solver:
  • 9 Answers
Drainage problems can be caused by:
a) Blocked Filter chamber
b) Blocked Sump
c) Blocked Drain Pipe
d) Blocked waste pipe
e) Failed Pump
You can check the sump and drain pipe are not blocked by disconnecting the drain pipe from the undersink trap or waste pipe and lowering to a bowl on the floor. The water should drain out into this bowl under gravity if there are no blockages. Bear in mind if you have disconnected the drain pipe from an undersink pipe if youpour the drained water down the sink it will flood into your undersink cupboard. If this drains then you check the waste pipe or undersink trap is clear. You should also check the filter chamber if it is accessible on your washing machine (not all are). I would recommend you unplug the machine or take the fuse out of the switched socket before doing this. Drain the drum as above before doing this or you will get a gush of water coming out. You will usually have to remove a cover from the bottom of your machine to get to the filter chamber and twist it ant-clockwise to unscrew it. Check for any coins buttons etc trapped in there. If there is nothing there check the impeller will turn relatively easily by hand. If you still can't find the problem you might have a faield pump and I would recommend contacting an enginee
Posted on Apr 04, 2011
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
I have an Indesit WIXL123 washing machine that wont drain! Have checked all pipes, no blockage, have replaced pump but it still refuses to work! Any ideas?
Since I have never physically worked on a Indesit, I can only tell you what a normal washing machince diagnosis would be: Drain pump is not functioning. Possibly something clogging the intake (count you socks) or just stopped working.
My supplier does not have Indesit parts so can't give you the part number for the drain pump.
Oct 03, 2011 | Indesit W 123 Front Load Washer
Hi I have no power to my WIXL123 washing machine. I replaced 13A fuse - still no good. checked the power socket - works fine. what part could be faulty?
ds nanra, you need to look first at where the power cord enters the washing machine. It then connects to the terminal block on the inside. There is where you need to check for loose/burnt connections. If you have the means (a voltohm meter or continuity tester) you could check the power cord itself for continuity, which would mean that the cord is fine if it has continuity. This is the first place you need to check. Other than a visual check for obvious defects on the power cords connections inside the washer, you would have to test it with a meter for definitive results.
If you have any other questions, dont hesitate. I would be happy to help you out further.
thanks,
mike
Jul 19, 2011 | Washing Machines
Lost manual can I download a new one for an Indesit Washing Machine WIXL123
If you go to the site below, you will be able to download the user instructions to your printer, or hard drive.
WWW.INDESIT.CO.UK
In the menu on the left side, click on--
Indesit user manuals
then enter your model number in the search box, and down load.the instructions.
Please leave feedback for my solution.
Thankyou.
Jan 14, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Boiler broke down
if you have two hoses going into it probably not
Jun 10, 2009 | Indesit W 123 Front Load Washer
Theres no power to my idesit wixl123
From what you wrote I can only hint that a fuse within a machine must have played its part for some reason so you better not mess with it. Call a repairman.
Apr 20, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
336 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
