Question about Mantis 2-Cycle Tiller
The cord dosen't retract when i try and start it
  • 718 Answers
Go to smalleng.com they have a video for just what you are looking for. Good Luck...
Posted on Apr 03, 2011
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
Mar 19, 2016 | Electrical Supplies
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Starting cord won't retract
if its brand new take it back tell them the retraction spring is broken and fix it
Jul 25, 2013 | Garden
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Mantis 2-Cycle Tiller Logo
89 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
