Question about Karcher K2.26 Electric Power Washer
When i switch my karcher on the motor makes o noise and does not turn
  • 3 Answers
I have a water cooled K5.140, barrel shaped karcher. Mine suddenly stopped working. Bit of a faff getting the casing apart but not beyond most competent car repairers. Once on the becnh look where the power cables enter the motor unit. Mine has a black box with clip on cover. Look between that and the metal of the motor/pump. There is a thin plastic toggle that will be stiff. WD40 on it and move the flat lever underneath it up and down with a flat screwdriver. This toggle and lever shuts off the power when the water pressure in the pump is high, so if it is stuck open you have no power to the pump. Took me less than 5 mins and a squirt of WD40.
Posted on Aug 23, 2012
  • 34 Answers
This sounds like you may need a new capacitor. It is not a costly part to get. What the capacitor does is "jump starts" the motor so if it broken the motor will not start.
A test you can do is if you take off the front caseand then set the machine up as if you were going to use it. then when you turn on the machine quickly push the fan blade of the motor with a flat headed screw driver. If this makes the machine start to work, then you know that you need a new capacitor.
Just be carefull when doing the test.
Please remember to thumbs up :)
Posted on Apr 04, 2011
2 Suggested Answers
  • 88 Answers
SOURCE: karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Posted on Jan 20, 2010
Karcher k3-91m electrical box
There is a strong possibility of a defective switch.
Aug 12, 2016 | Karcher Garden
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
My presure washer will not turn on.
does it make any noise when connected to mains,if yes then two possibilities, capacitor is faulty, or motor damaged.
If no noise, then input fuse or motor open circuit. also check cable for damage.
Nov 18, 2013 | Karcher Garden
Karcher b302
see if you can spin the cooling fan of motor if so you may have a bad capacitor on motor
Jul 29, 2013 | Garden
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
I have a Karcher 3.49M purchased 8/2/09. Using the washer I inadvertently turned on after changing hoses, but forgot to turn water back on; this activation lasted only a couple of minutes before I realized...
Normally when you dry run a machine you damage the pump so it would probably need changing. The motor might be Ok but for you to fix it you will need to take it to a Karcher dealer/service center.
From experiance it sometimes can be more cost efficient to purchase a new Karcher machine and get the 12 month warranty than spending money on an older machine.
Jan 19, 2011 | Karcher PSI Electric Pressure Washer
Karcher K2.91M nlets water in and out but won't
Dec 04, 2009 | Karcher K2.26 Electric Power Washer
Karcher hds 501c motor wont turn
never try to turn it on unless you squeese the trigger at the same tme it cant activate the pressure bypass unless it is running you will get ahumming noise and if you leave it on like that you will burn the motor out try that first if still no good come back to me
Aug 09, 2009 | Garden
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K2.26 Electric Power Washer Logo
386 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
