Question about Casio FX-250HC Calculator
Exponents and order of operations
5.5+( -1)-3)
5(-6)zero power
Posted on Apr 02, 2009
TAKE -3*-1+5.5 AND U SHOULD GET UR ANSWER
Posted on Aug 21, 2008
8.5
Posted on Aug 13, 2008
What is factoring and give the examples
Quick-Start Guide When you enter an expression into the calculator, the calculator will simplify the expression by expanding multiplication and combining like terms. At this point the calculator will attempt to factor the expression by dividing a G C F, and identifying a difference between two squares, or factorable trinomials. Use the following rules to enter expressions into the calculator. Variables Any lowercase letter may be used as a variable. Exponents Exponents are supported on variables using the ^ (caret) symbol. For example, to express x 2, enter x ^ 2. Note: exponents must be positive integers, no negatives, decimals, or variables. Exponents may not currently be placed on numbers, brackets, or parentheses. Parentheses and Brackets Parentheses ( ) and brackets [ ] may be used to group terms as in a standard expression. Multiplication, Addition, and Subtraction For addition and subtraction, use the standard + and - symbols respectively. For multiplication, use the * symbol. A * symbol is optional when multiplying a number by a variable. For instance: 2 * x can also be entered as 2x. Similarly, 2 * ( x + 5 ) can also be entered as 2 ( x + 5 ) ; 2 x * ( 5 ) can be entered as 2 x ( 5 ). The * is also optional when multiplying parentheses, example: ( x + 1 ) ( x - 1 ). Order of Operations The calculator follows the standard order of operations taught by most algebra books - Parentheses, Exponents, Multiplication and Division, Addition and Subtraction. The only exception is that division is not currently supported; attempts to use the / symbol will result in an error. Division, Square Root, Radi cals, Fractions Division, square root, radi cals, and fractions are not supported at this time. A future release will add this functionality.
that's all I can say basically I learned it this way.
Jul 09, 2015 | Office Equipment & Supplies
How do I enter ln55-1 divided by 2? The answer is 1.5 however I'm coming up with 1.99
Be careful with the order of operations. Try (ln(55)-1)/2You can never have to many parenthesis. remberr PEMDAS ln is an exponent so you want to put it inside parenthesis in oder to follow the Order of operations.
Apr 10, 2015 | Texas Instruments TI-83 Plus Calculator
How to convert Fahrenheit to Celsius
Put 70 in for F, and apply BEDMAS, the order of operations, brackets, exponents, division and multiplication, and finally addition and subtraction. In this case, we have to do the brackets first before the multiplication and division. The answer should be 21 degrees Celsius.
Feb 24, 2015 | Office Equipment & Supplies
Convert Fahrenheit to Celsius 70F to C by applying the formula (F-32)*5/9
What is the answer for this problem 2 - 2 x 2 + 2 = ? for mdas rule
I'm assuming you mean the PEMDAS rule.
2 - 2 * 2 + 2
= 2 - 4 + 2
=-2 + 2
=0
The answer is 0.
Nov 06, 2014 | Acer Ferrari 1100 Notebook
What is the answer to to this (x^5)^3(x^3)^4
We have to follow BEDMAS, the order of operations, where brackets are first, then exponents, followed by division and multiplication, and finally addition and subtraction.
Also, we have to use the exponent law of an exponent to an exponent, we multiply the exponents with the same base.
If we forget this, we can always do it the long way.
(x^5)^3 = (x^5)(x^5)(x^5) = x^15
Similarly, (x^3)^4= (x^3)(x^3)(x^3)(x^3) = x ^12
Now that we have done the exponents, we can multiply x^15 by x^12 and get x^27.
Good luck.
Paul
Oct 05, 2014 | Office Equipment & Supplies
I have a TI-84. It gives me a syntax error when I try to enter problems with negative exponents.
Use the (-) key (just to the right of the decimal point key) instead of the - key when entering a negative number (not just exponents).
- is used to subtract one value from another. (-) is used to negate a value. - operates on two numbers, (-) operates on one.
Mar 14, 2012 | Texas Instruments TI-84 Plus Calculator
Is it possible to calculate cube root or higher with BA ii plus?
To extract the roots of orders higher than 2, you can use the universal power key labeled as [Y to x]. if the exponent is an integer 3, 4, 5, 6 etc.
it gives the cube the 4th power, 5th, 6th, etc.
If the exponent is 1/3, 1/4, 1/5, 1/6 you calculate the cubic root, the 4th root and so on.
When you use it to calculate the roots, the radicand (the number the root of which you are calculating) must be positive, otherwise you may get the result as a complex number.
The syntax of the command is value [Y to x] (1/ order of root)
Ex: cube root of 27 is entered as 27 [Y to x] (1/3)
Feb 21, 2010 | Texas Instruments BA-II Plus Calculator
Negative exponents? .825/(10^(-3)) ? Not sure how to get it to do the negative exponent.
You entered it correctly. Although you can leave out the parentheses if you want. The calculator will do exponents before it does multiplication or division just like it does multiplication and division before it does addition and subtraction. It has a built in order for hierarchy of operations. You only need to use parentheses if you want to do something that is different from this order. FYI, dividing by a negative exponent is the same as multiplying by a positive exponent. You could enter it in either way. .825/10^-3 = .825*10^3 = 825. I hope this helps you out.
Dec 02, 2009 | Texas Instruments TI-30XA Calculator
How can i do exponents on my calculator
you type in 5 (or any other number) and then use the carrot (exponent) button that looks like this: ^ and type in your exponent (5) and click the equal button
Apr 13, 2009 | Texas Instruments TI-30 XIIS Calculator
Casio FX-250HC Calculator Logo
146 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
