Question about I-BEAD 200 (128 MB) MP3 Player
I want a file format for i-bead 150M - I-BEAD 200 (128 MB) MP3 Player
POTHWFLANAD1
You should describe your problem with a little more detail!
If you search on the web, you find some posts, that they do not have drivers and that this device does not work on WinXP, Vista or 7 without drivers. It is said that it works on LINUX. So what do you use? Do you have drivers installed for it?
What do you mean by 150m in your question. A ethernet-network may noot be longer than 90m + 6m +4m from device to device. If you need to brifge 150m you need a repeater or, even better, use a fiber-connection.
Mar 22, 2014 | Eforcity (PUSBLANXAD01) USB Network...
Cant connect the wifi edimax wireless br-6228ns
Here is the manual on to set it up.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6228nSnC/BR-6228nSnC_UserManual_v1.zip
From the manufacturers website.
Try setting it up according to the manual. If you need help you can contact the manufacturrers technical help here. Support Services
Aug 01, 2013 | Edimax Network BR-6228NS Wireless N 150M...
Peavey 150m power amplifier - no audio, hum
Bad caps probably..old unit, do you have a capacitor analyzer...if not you might find a Sencore LC102 to test caps with on ebay...
Jan 16, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
Hi my name is Nick I have 1 question. Suppose a bead maker wants to separate 10,000,000 beads into boxes. She will put 100,000 beads into a box. Into which box would she put the 4,358,216th bead?
If the bead maker is putting 100,000 beads into each box, then it will take her 10 boxes to package 1,000,000 beads. To package 4,000,000 beads (which is 4 times as much as 1,000,000), she will need 40 boxes. An additional 3 boxes (we're now up to 43 boxes) will allow her to separate a total 4,300,000 beads. Bead number 4,358,216 is between bead 4,300,000 (requiring 43 boxes) and 4,400,000, and she will need another box to package those beads, so we can deduce that bead 4,358,216 will be placed in box number 44.
If you found this solution helpful, please leave a positive rating!
Aug 29, 2011 | Computers & Internet
How many tracks can I get on the mp3?
Hi. Music files varies on sizes it depends on the length and quality of songs. The mp3 you have is a 128 MB storage for your music. It can store up to 20 to 28 music files depending on the kind of music you want to put on your mp3.
I hope this helped solved your problem. Have a nice day!
Mar 08, 2011 | Sanyo DAB-150M MP3 Player
IBall Baton 150M Wireless-N Router driver
iBall Baton 150M Wireless-N Router or any routers do not need drivers to work on your PC. Just the configurations settings provided by your ISP account.
Only Wireless adapters ie PCI or USB interface needs drivers for the device to work on your PC.
Here is a link pdf help file to help you configure your router to work on your PC/Laptop.
Hope it helps.
Dec 05, 2010 | Computers & Internet
I formatted my i-bead mp3 player.. i got a message "refomatted error" i couldn't heare any songs how to solve this problem
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Comments: - 1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" Good Luck ..... dont forget to rate me......
Apr 06, 2010 | I-BEAD 200 (128 MB) MP3 Player
My I-bead mp3 was formatted accidentally...
Your songs are most likely gone, formatting erases all of the data on the player.
Always back up your data on a seperate disk. Good luck.
Mar 08, 2008 | Electronics - Others
I-BEAD 200 (128 MB) MP3 Player Logo
47 people viewed this question
Top I-BEAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an I-BEAD Audio Player and Recorder Expert? Answer questions, earn points and help others
