Question about Disney Princess MCP DVD2050P DVD Player
No power fuse is ok what now - Disney Princess MCP DVD2050P DVD Player
  • Disney Master
  • 506 Answers
It is most likely a fault within the switchmode power supply - due mostly to the ever infamous electrolytic capacitors and zener diodes (the capacitors fail which increases DC voltage through the diodes, shorting them out). It could prove expensive to repair by a service centre, if that's what you want to do. You can submit the player to your local repair centre for a quote, and get a second opinion on the exact nature of the problem, then you can make a decision about any further action for it from there.
These days, so many DVD and Blu-Ray players are becoming cheaper to buy, while repairs on the same units become more and more expensive and/or uneconomical as parts are often difficult or impossible to obtain. Unless you have electronics experience, knowledge, A-grade soldering/component measurement and diagnostic skills, plus an understanding of service manuals, do not undertake the repairs yourself.
However, it is up to you what you decide to do from here. Cheaper and easier to buy a new player - consider this option ONLY as a last resort.
Posted on Apr 03, 2011
No power to fuel pump
What engine?
you say everything is ok but have you checked for power at any of these components to see where you are losing power. Check for power at the fuse. The fuel pump fuse should have two pins with power and two pins with ground. Check each pin while turning the key to the run position. There will only be power/ground on some of the wires for 3-5 seconds when the key is turned to the run position. It may be helpful to have a helper in the drivers seat turning the key while you test.
Sep 05, 2014 | 2000 Dodge Durango
My ac stop working,I checked compressor ,it's ok ,no power to compressor
Some possible causes are the system is low on freon, a faulty compressor clutch, faulty low pressure switch, relay, fuse, or control switch.
Do you have power at the fuse and the relay ?
Jul 15, 2012 | 2001 Chrysler Sebring
Fan motor won;t turn on blower motor is ok fuses are ok relay is ok but i still have no power at the switch what am i missing
sounds like the wire from fuse box to switch is bad, a fuse completes a circuit or route the fuse takes power in on one side and sends power out the other, I've seen it many of times but cant confirm its your problem. but the power comes in and the power goes out and the fuse checks good but on the out side it is not making connection to the wire or connector on the back of fuse box. run a jumper wire from a positive power source to the positive in on the switch does it work is there a good ground to the motor
Jan 14, 2011 | 2004 Dodge Dakota
Driver side power window doesnt work
Its possible, check underhood fuse box, the position 6, 60AMP for Power Windows
Other details can find in the Ford-Explorer-Owners-Manual (page 187 and next)
If the fuse is OK, take off the trim panel to check the windows motor, windows switch and wires.
Hope helps (remember rated this).
Jul 23, 2010 | 2003 Ford Explorer
Power turns off randomly
Hello :
First check the power cord ! If it's OK , then you need to check if the fuses are OK also . If fuses are OK , then the problem is with the power PCB . Fuses are easy to be replaced . Power PCB is a bit complicated . You need to take your coffee maker to a repair shop for that .
good luck .
rate please !
Mar 19, 2010 | Keurig Elite B40 Coffee Maker
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Power outlets don't work. All fuses in both fuse
These are very simple circits, a power and a ground. Issues like this are usually a fuse, where the fuses checked with a test light, meter or just by looking at them? Fuses are decieving sometimes.
If they are ok, with a test light check for power at the outlets.If no power and the fuses are good then you may have a broke wire, or a ground issue. Let me know what you find.
Feb 19, 2009 | 2000 Dodge Caravan
Disney Princess MCP DVD2050P DVD Player Logo
74 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
