Question about Refrigerators
How to fix hotpoint ff187e the top of the fridge is not working and not getting cold
    Brigadier General:
  • 3,917 Answers
Hi
It's possible that the compressor is dead or not working properly. Also try to dust off the coils in the back.Check the back wall or floor of the freezer section for frost. Check the freezer (evaporator) fan to see if it is running. Check the condenser coils ( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Also check the bellow link to get a useful article to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsstoppedcompletely
Please get back to us if you have further query else please accept the suggestion.
Posted on Apr 03, 2011
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
Hotpoint ff187e
sounds like you have a bad contac on the wiring attaching to the socket but if this is a domestic refrig is a 115volt but the name plate inside will tell you for sure.
Oct 23, 2013 | Refrigerators
Hi, my hotpoint fridge/freezer FF187E its my fridge area not cooling and my freezer is working but starting too get ice around the sides and that.
sometimes its just easer to replace the defrost termination thermostat get a 55F for about 15.00 bucks and just change it, if it works thats the problem, if not, it may be the element or defrost timer
Mar 12, 2012 | Refrigerators
What setting should the hotpoint frost free ff187e be on ?
forget "settings"get a thermostat and run the freezer at -18c and the fridge at +5 these are the ideal temps for storage and economy.
Aug 25, 2010 | Refrigerators
Light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Dec 08, 2009 | Refrigerators
My hotpoint ff187e fridge is not cold, the freezer is working but getting a build up of ice which i have defrosted. tried turning off. when i open the fridge does not feel cold,not sure if the fan is...
we had same problem,apparently there is no such thing as a frost free fridge/freezer, you have to turn your appliance off for at least 3 days because the freezer has a build up of ice which stops the fridge from working, you must leave it switched off for this time otherwise it will just ice up again.
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
Flashing lights on hotpoint fridge
I have a hotpoint future FF187E both lights are flashing how can i stop them flashing ?
Aug 04, 2009 | Refrigerators
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
347 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
